Chassis extension Correction
I have done two chassis extensions adding 50mm by carefully cutting two chassis bodies to the correct individual lengths and superglueing them together with small pvc foam braces on the inside overlapping the join. I wanted to put 1/32 Kenworth Semi Tractor bodies on the xmod so I lengthened the chassis and then added a second shortened , non-powered axle at the back for the dual axle look. The chassis is holding together well but you have to be careful in the cutting and joining/glueing. I have attached a scan of how I would do it to add approx 25mm length.
