07-13-2004, 02:16 PM
Do you getto dremel?
just a headsup if you run a rear swaybar you'll want a front too otherwise when the wieght transferst to the front corner i'll pick up the rear wheel and make it diff out.
07-14-2004, 12:33 AM
boro dori style RC
do you tighten it all the way? cause you dont want it to lock..mines fine it pushes the inside rear down as the outside compresses f.
shift drift: in a way it is but the trishock pushes the suspension outward and the bar holds it together. i would say it helps preload the springs sorta...
r34 - rwd
r34 - awd
dd4 - fwd
07-14-2004, 02:58 PM
my suspension is locked whe the weight transfers to the front during a corner it lifts the inside rear
07-15-2004, 12:33 AM
boro dori style RC
you want to loosen it so the joints can swivel freely. that should help solve youre problem. an limited slip diff would work too
r34 - rwd
r34 - awd
dd4 - fwd
07-15-2004, 02:35 AM
i had a locker setup for the stock diff that i was going to post after some more tests and im glad i tested it further because it screwed it self up. im starting a new version tonight.
07-20-2004, 11:07 AM
It's Really Fast!
If you used a very thin piece of plastic, it would still flew, yet would still have suspension.
Project Bad Brushless:
Just say no to giant sigs.
07-21-2004, 02:11 AM
boro dori style RC
thats what im running now. the packaging for upgrade parts
r34 - rwd
r34 - awd
dd4 - fwd
