Old 07-06-2004, 11:30 AM
NHawk NHawk is offline
Throttle hesitation - normal?
I have noticed that there seems to be some hesitation in the car's response to throttle input. When throwing the throttle trigger, either in forward or reverse, it seems take a second or so before the car responds to that signal input. Is this normal for the stock motor and electronics and is there some adjustment(s), mod(s), or fix(es) to get the car to respond quicker to signal input?
Thanks,
N-Hawk
P.S. Hmm... Should I have put this in "Mods" or "Science"? Sorry if it's in the wrong spot.
Old 08-02-2004, 01:36 AM
xodus xodus is offline
XmodSource Dot Com
Hi, Well first..the best place to put a thread like this is just in the XMOD forum; Either way its fine. You'll just get look's over there. As for the problem, You may want to check your antenna wire connection. See if its soldered onto the board good and see if the wire is connected to the metal connectors good. Also make sure its screwed down good. Besides that, you may have some interference from your surroundings like microwaves or something like that. It can also be a electronic problem but im not too sure what you can check for that. I had some problems like this but it was my antenna not being connected to the metal connector well enough; I simply soldered it and I was on my way. I hope some of this helps, good luck - Dean
www.xmodsource.com
Old 08-02-2004, 01:05 PM
newbitowner's Avatar
the antenna wire might be touching another wire...that may cause interference.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 08-06-2004, 11:13 PM
hotrod29728's Avatar
hotrod29728 hotrod29728 is offline
Send a message via AIM to hotrod29728 Send a message via Yahoo to hotrod29728
The antenna wire could have been rubbed bare and could be touching something causing a short that interfers with the reception... Check the wire for bare spots and also check the connection of the antenna... Also check to see if the steering range is turned up all the way...(little black knob above your hand when holding controller pistol style) turn it to the right till it won't go anymore... Thats just some suggestions....
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Throttle delay Hoverdown3k Micro-T General 12 08-19-2009 10:22 AM
proportional throttle ilkera ZipZaps SE 10 11-02-2003 05:50 AM
Turret Insides and Motor Behavior - Is this normal? Bistromatic Combat Digi Q 0 10-17-2003 05:09 PM
Sold Pro Microsizer Bought A Normal One 2G2SILVERSTRAT Bit Char-G / MicroSizers 5 07-04-2003 11:31 PM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 12:08 PM
