05-23-2004, 07:53 PM
3D Racer
electric superchargers
so i was watching some show on spike tv and they were installing a turbocharger into a ford mustang and they explained that it was basicaly a fan powered by the motor that forced more air into the air intake to increase speed and power. then i started thinking about how if you turn a motor mechanicaly (manually) it will act like a generator thus creating electricity. so if were able to hook a zipzap motor to a xmod motor and then maybe some sort of belt system to turn the zz motor it would generate electricity which would be sent directly back to the xmod motor. do you understand?
05-23-2004, 08:59 PM
Tiny RC Guru
sorry to burst your bubble dude but for one thing a ZZ motor wouldnt do **** and for two it has already been thought of except it was usin a Xmod motor i never told anyone this but instead of being a generator i think it would just power both of the motors and decrease your speed but it would give you an assload of tourqe its a good idea but nobody thinks it will work and im not tryin to be mean at all im jus tellin you so if i sounded mean im sorry
05-23-2004, 10:42 PM
You cant get free energy, the effort to make power would be more than the power you made...
example (that I tried just for the heck of it..
4aaa cells hooked to
130 motor (like Xmod but mine ws Mini-z)
the motor shaft of this motor was hooked to another motor... wich was then connected to my volt meter...
it took 6 volts from those 4 cells to make about 2 or 3 volts pop up out of the other motor...
its not enough to bother with extra weight or mechanical drag... which would slow the car down 100x more than anything you would gain out of it (which would be basicly no gain).
05-23-2004, 10:51 PM
Tiny RC Guru
yep thats what im sayin the drawbacks far outway the um good stuff lol
WWWWOOOOOOOTTTTTTTTTTT MY 200TH. POST WWWWWWWWOOOOOOTTTTTT!!!!!!1
05-24-2004, 09:57 PM
TinyRC Innovator
i could be wrong but i think he means have your reg x mod motor running like reg and have the zip zap motor hooke up to it and the offput of running the car would turn the zz motor and generate electricity kida like a generator which could then be sent back in to the x mod motor thru the esc..im prolly wrong but it might work and honestly i have no clue how to do it ..so i prolly didnt help at all but it sounds like a good idea to me
IF YOU LIKE THIS MOD OR ANY OF MY OTHER MODS CHECK OUT OUR SITE AT
05-24-2004, 10:20 PM
Tiny RC Guru
thats exactly what hes sayin but....... electricity ALWAYS takes the easiest course and the easiest course is to power BOTH motors and not make the ZZ work like a generator.EVEN if it did work like a generator a ZZ motor wouldnt do **** you might as well not even do it. See here (i should really know what im talkin about after i got the **** beat out of my hopes here LOL):
http://www.tinyrc.com/forums/showthr...ight=generator
05-26-2004, 01:59 PM
3D Racer
isn't there some sort of electrical component(ex: resistor, transistor) that only alows electricity to travel one way or something.
05-27-2004, 07:11 PM
Yes, it's called a Diode.
Energy is neither created nor destroyed, it merely changes forms. The ZZ motor being used as a generator is defeating the purpose. Even if the ZZ motor was 100% efficient(which is practically impossible) you're only going to be exchanging an equal amount of mechanical force for an equal amount of electrical. So you'd be taking mechanical force from the main motor to run the ZZ motor that will be giving the electrical force right back to the main motor. There would be no gain, and since the ZZ motor is nowhere near 100% efficient, you would actually be taking a drastic loss by doing so.
Sorry, no vids for now.
05-27-2004, 11:01 PM
5Zigen
yeah basicly what he said...
OMFG!1!!1!!one!1!
MY 200something"th POST!!1!!!!!!!!
LOLLERSKATEZ!111!!!!!
Try And Sleep Now.
DRIFT my ANTI-rice
05-27-2004, 11:19 PM
Tiny RC Guru
Originally posted by SHIFT_DRIFT
OMFG!1!!1!!one!1!
are you makin fun of me?
why do you curse God what has he done to you?
