04-18-2004, 08:31 PM
4 wheel drive....slowwwwww
hey, well i recently installed 4 wheel drive into my car and it seems to be alot slower than before. theres a huge difference on handleing but im not sure if the hit on speeds is worth it, has anyone else had this problem? just curious, thanks.
04-18-2004, 08:36 PM
got supra?
Re: 4 wheel drive....slowwwwww
i saw this too. i just put a bigger motor in it
xmod
blue supra
6 cell
all upgrades[by rs]
04-18-2004, 08:44 PM
no replacement for displacement
yah, I installed AWD, but only noticed better performance, because I installing a stage 2 motor as well.
If you don't have the stage 2, I recommend it.
The bearings, awd, stage 2, and suspension make a noticeable difference.
-Jason
04-18-2004, 08:46 PM
i do have the 2nd stage top speed motor in there. and i had it before i put the 4 wheel drive in as well but there seems to be a big difference in speed.
04-19-2004, 03:54 AM
more moving parts = more work = more drain/strain on the motor... = slower car
04-19-2004, 04:00 PM
5Zigen
and check to see if all gears mesh together corecetly.
and cleanout ur wheels of dirt and hair.
Try And Sleep Now.
DRIFT my ANTI-rice
04-19-2004, 09:57 PM
i'll put it this way... to push all-wheel drive to it's max... use an aftermarket HIGH tourqe motor... don't go trying to use a satge 1 stock motor... lol... unless you want a slow car with good handling.
have a fast car with great handling... upgrade to a sleek motor like a team orion modified 180 or a motor from atomicmods.com or xmodspeed...
carbon fiber decks, carbon fiber driveshafts, carbon fiber and aluminum lips, aluminum wheels nuts, replacement stock parts and cheap xmods starter kits.
LAUNCHING MAY 7TH
04-20-2004, 09:47 PM
have a fast car with great handling... upgrade to a sleek motor like a team orion modified 180 or a motor from atomicmods.com or xmodspeed... [/b]
or the NML Mega-X 180 sized motor...if u can afford it
-yellow skyline
-wild body kit w/ stock spoiler
-180 sized mega-x motor by NML
-2x2 stack FET upgrade
-stiff springs in rear, medium springs in front
-3.0 toe-in
-rim upgrade
-soft tread tires
-vinyl and decal upgrade
-6th cell upgrade
-command logic lights
-rs metal ball bearings
-alloy cup joints in the front
04-22-2004, 06:07 PM
if you are going to install AWD you need to do the bearings before or at the same time or you will have a slow car.
