03-20-2004, 12:29 PM
metal nuts with nylon threads would be nice!
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
03-20-2004, 01:11 PM
0reZepyT
i like to see wheels and tires that are plastic, resemble brand name aftermarket wheels from enkei and other companies, and are wider. they should have the same offset so that the extra width would protrude outwards. i like to see treaded tires that have sharply cut grooves in it, not the rounded groove edges of the treaded tires from the RS tire upgrade kit. (hope you know what i mean, if not i'll throw up a pic later)
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
03-21-2004, 03:47 PM
Nylon locknuts are availble for the Mini-Z and are the perfect fit for the X-Mod. Check the sister site, mini-zracer.com
Any 2mm locknut will work. Also check the FAQ section, this has been discussed in depth somwhere in there.
03-23-2004, 04:44 PM
I'm not a pyro, really.
TypeZer0, why plastic tires?
has anyone tried to use a CD as a wheel? we used to use them for that for some project in wood working.
NEVER UNDERESTIMATE THE POWER
03-23-2004, 09:20 PM
I'm a big fan of the 15 degree GPM sport edge radials for the Mini-Z. They work well on the carpet that I run on. Once it actually gets warm enough to run outside, I'll have to find the preferred setup for asphalt.
04-06-2004, 11:22 AM
Do you getto dremel?
id like to see somthing like a micky thompson sportsman tire in a soft compound they look like the duratrax street trac tires
04-06-2004, 05:56 PM
0reZepyT
actually, i meant plastic wheels and rubber tires. didn't really think when i was typing
04-07-2004, 02:31 AM
boro dori style RC
i want some tires that are nice and grippy but dont crumble off like the xmod ones. i have a pair that i stuck on my rear and the thread is gone after 2 days of drifting in my garage...
r34 - rwd
r34 - awd
dd4 - fwd
04-07-2004, 05:26 PM
IDK if its possible but softer rubber on the outside and harder on the inside. that way the tires wouldnt come off as easily like the totally soft ones do. how about paddle tires?
04-10-2004, 10:29 PM
one word, foams, better foams than the RS ones. or perhaps silicone. and how about a modified ball diff to fix the annoying slip from the washers not locking to the hubs? possible? I have ideas. and how difficult would it be to make alu. outer shafts and universals?
Nissan Skyline GTR v-spec
AWD
suspension upgrade (soft rear med front)
180 size motor, custom made heatsink
GPM alu front knuckles, shocks and center bering holders.
more to come...
04-14-2004, 11:53 AM
maybe they could replace the rear with aluminum universals too. no more broken cup joints. maybe they could sell them with rubber boots over them?
06-14-2004, 02:32 PM
its just a thought but if you guys could make like a tire for like goin in the dirt and make sumthin that fits around the holes where dirt could get in (or just b cheap like i would and stuff cardboard up there) but yeah its not much to work off of but i think its possible.
 YAY MY FIRST POST
why must we try to fly when all we will do is die?
06-23-2004, 02:54 PM
Knobby tires! XP
06-28-2004, 07:22 PM
It's Really Fast!
Originally posted by Akira36
I almost forgot, another Idea I've been pondering a tire purpose made to adjust to the camber-happy characteristics of the rear suspension, high profile on the outside, low profile on the inside..
I attached a crappy mspaint diagram to give you an idea of what I'm talking about.
The problem with that design is it will not correct the problem, and instead make it worse. If you reverse it, It will make it a whole lot better.
Project Bad Brushless:
Just say no to giant sigs.
07-01-2004, 11:12 AM
Something like this  I run these wider and higher profile tires for drag. These also have a tread.
You know nothing. Hell is only a word, reality is much much worse.
