Old 02-28-2004, 03:35 AM
codedat
Got an e-mail Fri stating my order has been shipped
Hopefully I will be able to get going on the adjusted version. Neuro I will post how well it works. I know that the TO-263 packages have different heat Tol than TO-220 pk.
Old 02-29-2004, 10:00 PM
neurokinetik's Avatar
Originally posted by charliebrown
Anyways, for some quick Q's: With your FET setup, the amperage limit is pretty high, from what I hear, so I'm thinking of getting the Team Orion Elite Stock 180 motor, and taking about 20-25 winds off the armature. It will have a bit of a high current draw, but I'm guessing the FETs you're using will be able to handle that.
If you go that low, it won't have any torque at all. I've tried a 15 turn double, and even it isn't an acceptable performer, IMO. (It sure has great top end just spinning with no load on the bench, though.) It takes about 1 full second or more to spin up.
Old 03-05-2004, 06:47 PM
meteoraclown meteoraclown is offline
Originally posted by codedat
Hopefully this should clear things up. Note connecting directly to the batteries is ok but don't forget to connect to the main PCB.
Here is a revised img
If the picture doesn't show click the link here
I belive this is what Neuro said it should be. Note directly connecting the battery is ok but remember that the main PCB needs power also.
I fix the link.
ok this is cool and all but which is ic5 and ic6. Is ic5 the left one and ic6 the right one or vise-versa
Old 03-05-2004, 07:53 PM
codedat
I re-labled them. sorry was in a rush on a quick revision. Recheck the link again.
Old 03-06-2004, 06:39 AM
ok ty cause i'm kinda new to electronics and stuff.
Old 03-07-2004, 06:07 AM
codedat
No prob, glad to help. BTW check this out, it will help you on the basics of electronics.
Basic Electronics
Old 03-15-2004, 03:08 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
neuro, i breezed through most of this thread and i dont' think this was asked. does your FET upgrade board maintain the brake function?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 03-16-2004, 08:06 AM
Yes. All original functionality is retained.
Old 03-18-2004, 08:09 PM
geofroley's Avatar
R34 Skyline is God
Code I can't see your pic.
EDIT: Nevermind, saw the link.
My Bit: Phast motor (Orange)
Old 03-18-2004, 08:12 PM
geofroley's Avatar
R34 Skyline is God
Does anyone know where I can get some colored wire from?
Old 03-19-2004, 04:14 PM
geofroley's Avatar
R34 Skyline is God
Nuero, in your mod, where to we solder where it says + battery and - battery?
Old 03-20-2004, 01:07 AM
TypeZer0's Avatar
0reZepyT
go back a few pages and there are pics to show where to solder it
Old 03-20-2004, 07:45 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
Thumbs up
Neuro! great work man!... have you tried using those big fets without the stock fets.. i mean you will remove the stock fets then repllace it with those FETS?.. just curious
hehehe
Old 03-20-2004, 08:10 AM
geofroley's Avatar
R34 Skyline is God
Alright I found it, but is it on just on battery case?
By the way Nuero, what are the other FETs next to the IRF4905s in your pic?
Old 03-20-2004, 01:23 PM
That was the way I was running it, yes. Stock FETs were removed completely.
Yes, just run another set of wires from the battery cases.
The other FETs are the IRL3705N.
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
