03-13-2004, 08:48 PM
It's Really Fast!
Motor question?
Well, I might get an longer drive shaft, so I'm thinking aboutwhat kind of motor to buy. I'm thinking either a stage 11 from xmodworld or a MRS4 motor. Which one is better? I need a little more torque than what a stage 2 gives me, b/c I'm horrible off the line.
03-13-2004, 08:52 PM
I'd recommend getting the MRS4 motor (that is, if you're referring to the Micro RS4 Team Orion Elite Stock motor), and taking about 10-15 winds off each leg in the armature, rather than getting the motor that needs 5-6 cells to reach it's "full potential".
Chuckster...
03-13-2004, 09:38 PM
It's Really Fast!
I'm not taking the motor apart. I also plan on getting the regulator mod, and then popping in 18 volts, or maybe 27. What is the frying point on these motors?
03-14-2004, 08:34 PM
18v alone will have you looking for some damned good carbon brushes and new ways to cool the motor so the brushes and comms don't melt.
03-14-2004, 08:39 PM
It's Really Fast!
So I need a Ram Air intake and a cooling fan? So the RS4 motor won't handle it?
03-14-2004, 08:44 PM
Everything I've read on people running 4 Li Ions @16+volts leads me to believe the 180 motors can't handle the voltage as well as the 130s with good carbon brushes...
