Old 03-06-2004, 08:06 PM
Daazndood Daazndood is offline
New Curcuit board=fixed range?
hay. my friend has really short range, and he wanted me to ask you guys if buying a new curcuit board would fix that. answers would be appreciated. thanks
Old 03-06-2004, 08:16 PM
aperson's Avatar
aperson aperson is offline
the Reciever PCB Assy from CJ's faq right? thats a direct replacement for the 2 boards. you just need to solder the battery holders on and the servo on. if thats what you're talking about if not go to the XMODS section and do a search for "Extended Range?" for a fix
Old 03-08-2004, 02:49 PM
Check under the cover of the Command Logic Port for the L1 L2 inductors. The L2 inductor is the biggest cause for short range when its burnt out.
You can get a replacement inductor at www.atomicmods.com
Old 03-08-2004, 07:35 PM
RC 2NR RC 2NR is offline
TinyRC XModder
A little off topic...what does PCB stand for?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 03-09-2004, 07:36 AM
TinyRC XModder
Ah, thank you.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 03-09-2004, 06:22 PM
thanks for the replies. so am i supposed to buy the PCB thing or the servo assy?
Old 03-09-2004, 08:31 PM
TinyRC XModder
You want the PCB. The servo is what turns the car.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 03-12-2004, 07:22 PM
viperdout's Avatar
It's Really Fast!
I just put in a new recevier board into the existing board/servo/batt combo. Is that bad?
Old 03-14-2004, 08:29 AM
aperson's Avatar
i would get a servo too. then it will be easier to install that way too. then you have an extra servo to play around with. and you can use the old servo and battery holders. its ok. just be careful when you solder the wires on the battery holders that you solder it as quickly as possible. ive ruined a couple of them, the metal piece where you solder them gets too hot and the plastic melts and ruins the end of the battey holder.
Old 03-14-2004, 10:10 AM
viperdout's Avatar
It's Really Fast!
Yeah, I once did that on an MS controller.
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
