03-06-2004, 11:59 PM
New Tires!
Instead of using the Super Slick tires, use ZIP ZAP Tires. The Water-Tread ones really work better than the SS ones. I turn better now and don't spin out as much. I tend to slide more now
XMOD Yellow Skyline
AWD
Wide Track Bearings
IC-3
Soft Front, Monoshock
Hard Treaded
NML Stage 10, blue Gear
Carbon Fiber Driveshaft
03-07-2004, 10:17 AM
Re: New Tires!
Water Tread= All Season tires, right?
Chuckster...
03-07-2004, 01:04 PM
Basically, Water Tread=All Season in the Initial D Tuner kit. I think water treads fit better.
XMOD Yellow Skyline
AWD
Wide Track Bearings
IC-3
Hard Treaded
03-11-2004, 06:55 PM
Maybe its just me, but I find this to be a bit flawed. Granted, it does work. I noticed alot more grip and better handling, but after driving at top speeds and doing alot of high speed turns I've found that my right front tire will lose grip, "blow out" (slip off the axle), and cause the car to roll over. I am going to try to find a different all season/water tread to replace that tire with to see if it corrects the problem.
Edit: Yeah, fixed it. It works pretty nice now. I drove out in the garage (flat concrete) with a new tire and it worked much better.
I wish my Land Rover was a rotary
