Old 03-04-2004, 05:57 PM
Sky_Liner's Avatar
Sky_Liner Sky_Liner is offline
Send a message via AIM to Sky_Liner
Check out these FETS
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=2565
Do these FETs look right? I have done my research to learn that cutting the heat sink can severly damage the car. (am I right)
It also kinda look like these have a heatsink on them which I also thought was bad.
I want these but im not sure can someone give me some feedback on these things?
Peace
Old 03-04-2004, 07:08 PM
Those are the same FETs that Robert Byrd uses at AtomicMods.com They are legit.
The FETs themselves don't have a heatsink on them, however, a heatsink making contact with the FETs would aid cooling them. However, you'll generally have to cut the heatsink to make room for the FET stack at x3 or x4 stack.
Anyway, why go through ebay? Goto www.digikey.com and order them direct, probably cheaper too.
Old 03-04-2004, 07:40 PM
Sky_Liner's Avatar
Have you ordered from Digi-Key before? Do they take money orders? Also when I order do I have to order so many?
sry for all the questions.
Peace
Old 03-04-2004, 08:19 PM
Yes, I've ordered from them.
I don't know if they take money orders.
You can order as many as you want.
Old 03-04-2004, 11:03 PM
ninja828 ninja828 is offline
yes they do take money orders, so people w/o credit cards are not left out of the ever-advancing xmods world of mods
Old 03-05-2004, 08:57 AM
neurokinetik's Avatar
I don't think Digi-key carries the 4562s, though, at least, I've never seen them there.
Old 03-07-2004, 03:35 PM
Sky_Liner's Avatar
Ok so if I stack the fets and cut the heatsink the car will be ok?
I am just thinkin that something could get up there and mess up the fets or electronics. also what channel are the fets for the internal electronics?
Thanks
Peace
Old 03-07-2004, 10:44 PM
Jshwaa's Avatar
Jshwaa Jshwaa is offline
Send a message via AIM to Jshwaa
Mine have been fine thus far. It's not like you're going to be off-roading with your xmod.
Each FET IC is a dual N/P channel, so it has one of each. This is how two of the IC's make up an H-bridge.
Old 03-11-2004, 10:03 PM
They have the 7389s..
http://www.digikey.com/MKT/NewT011/I...nSO8Logic.html
Old 03-11-2004, 10:16 PM
Sky_Liner's Avatar
lol
Yea I was just looking at those I think im goin to order two of them (the 7389s).
Old 03-11-2004, 10:43 PM
just two? ur not gonna try stackin them?
Old 03-12-2004, 04:05 PM
Sky_Liner's Avatar
I meant to say four/ has anyone else used these fets?
Old 03-12-2004, 04:39 PM
Jshwaa uses them.
When I do mine, I will use the 7389s. I believe neurokinetic used them before he went with the larger P and N FET mod he has hooked up currently.
They are pretty common in our applications..
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
