Old 02-28-2004, 10:29 AM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Lightbulb new type of 'boost'
i have just thought of this and i was woundering if it would work. the light kit slot puts of a fair abouynt of volts, right? then can i wire the slot to the motor to get an extra 'boost'? i am not great at electrical things, so i really wouldent know the consequenes. if this would work it would be a very big boost!(i think)
--Chris
Aka...aero528
Old 02-28-2004, 10:59 AM
RC 2NR RC 2NR is offline
TinyRC XModder
The only probelm I can see is that the CLLK doesn't draw too many amps. You could run the risk of burning out a component on the board because the motor draws a lot more amps than the CLLK.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-28-2004, 12:43 PM
codedat
You could try but the stock wires would have to be replaced. Also you would need a back flow protection circuit so power doesn't flow backwards. Maybe worth a try. I also think there are two surface mount resistors going to the CLLK restricting current to about 20mA.
Old 02-28-2004, 03:16 PM
aero528's Avatar
like my dog??
well that would still make it go faster right? we need neuro...
--Chris
Aka...aero528
Old 02-28-2004, 03:30 PM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
sorry but...stupid idea...
naw ,it probably will not work and if it did..it wont give u any difference
sorry
Old 02-28-2004, 08:45 PM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
yes it would work the only problem is if you directly hook it it will constantly run the motor ass soon as you turn it on youd need something to hold it till you push the throtle.it will run the motor kind of slow though because the lights shine regular then get brighter whe you accelerate or brake so if you solve that problem then it will work and guys who said no it will be giving double current but this is similar to what somebody has already thought of exept they werent going to use the cllk port they were goingto completly wire it externally but still good idea
Old 02-29-2004, 04:56 PM
FlySkyline FlySkyline is offline
correct me if i am wrong, but i thought the lights on went on when the trigger is pressed. therefore it wouldn't always run. (i dont know if they always are on because i dont have them)
Custom Customizer- takin xmods to tha limits and hopefully back again for another run
Old 02-29-2004, 07:28 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
the lights are always on but they get brighter when you push the accelerator, brakes, or reverse. when the brakes are applied all lights come on.
NEVER UNDERESTIMATE THE POWER
Old 02-29-2004, 09:55 PM
neurokinetik's Avatar
Originally posted by SCRacing
Where do you think the lights get their power? The batteries are already giving your motor as much power as they can.
He's right. If you want more power, just don't install the light kit to begin with. You wouldn't be magically making more power by tapping off of the light socket, you'd just be diverting the power that would normally be taking the lower resistance path to the motor and running it through the high-resistance path through the light socket. If nothing blows up as a result, the best case scenario is that your car will go slower.
Old 03-01-2004, 02:47 AM
codedat
Hehe Neuro,
You beat me to the punch. I was trying to get him to try then tell us about it.
Old 03-01-2004, 02:57 PM
aero528's Avatar
like my dog??
who said i was going to try it, it was just an idea. i was asking if it would work, and if it would have it would have been alot more power. but , since it wont then i wount try it. i am not stupid.
--Chris
Aka...aero528
Old 03-02-2004, 03:02 AM
Bleek's Avatar
Bleek Bleek is offline
X-mod Innovator
but what about this my fellow x-mod friends..........
i have been thinking about this concept and mod too and here's what i came up with.
first you can tap into the light socket as it does dirrect current from the batteries, but dont send it right to the motor that would be like using no lights
so what you do is wire a capactor with alot of storage in parallel to the motor so the light socket is charging the cap. then when it fills up the cap or the car is under alot of strain it will pull some more stored power acting as a boost.
well thats how i thought it would work
just my $.02
++ Project X-mod 2006 ++
X-mod EVO with CVT tranny!
Old 03-02-2004, 06:26 PM
aperson's Avatar
the only problem with that is that the cap will be contantly charging since the lights are always on. so if you sit in one spot for a while the car on and TX on the car will jump on its own.
Boost Button otobot Bit Char-G / MicroSizers 4 02-24-2004 01:13 AM
? about boost cars shinigami579 Bit Char-G / MicroSizers 4 01-21-2003 09:54 PM
To Boost, or not to Boost.... DarthRacer Bit Char-G / MicroSizers 2 11-21-2002 12:49 PM
to boost or not to boost? boosted Bit Char-G / MicroSizers 3 11-12-2002 08:18 PM
K.I.T.T turbo boost? Racemonster505 Bit Char-G / MicroSizers 2 09-26-2002 07:24 PM
