Old 02-23-2004, 09:37 AM
Rez Rez is offline
I'm running the Team Orion motor at 7.5v on stock fets. Quite frankly, it's more car than I can handle. For dragracing, no problem, but taking corners is now a challenge.
Rez
a7i20ci7y
Seven Cities RC
Old 02-23-2004, 03:37 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
same here, i flip way too much on carpet
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 02-23-2004, 06:15 PM
00black_civic 00black_civic is offline
Neuro says a top speed stage 2 has better top speed but less torque than Team Orion. Is this true? Should I use blue gear and matching pinion? How much modding is needed for this to fit in a 6-cell Civic?
Sorry for all the questions and numerous posts. Im kinda new and dont want to screw anything up. Thanks.
Old 02-23-2004, 06:19 PM
Rez Rez is offline
That's true, but the Team Orion motor has better acceleration with the tallest gear than the lowest gear on a S1 motor. It reaches high speed very quickly. I used the blue gear and pinion.
To fit in a civic, you shouldn't have to mod anything short of the connector on the motor, unless it's going to get in the way of one of your cells. I don't know where you put your cells though.
Rez
a7i20ci7y
Seven Cities RC
Old 02-23-2004, 06:24 PM
Thanks for such a quick response would i have to worry about my friend catching up I will be Drag racing 40-50ft.
Oh yeah and my cells are mounted in the inside of the roof.
Old 02-23-2004, 06:29 PM
TypeZer0's Avatar
0reZepyT
well, you're just gonna have to find out who's gonna win the drag race. if he does catch up, then go back and do some more modding then race him again.
Old 04-20-2004, 09:16 PM
redninja redninja is offline
HPI 180 motor at 160 DEGREES!!!
OMG...After running my Xmod in the garage for about 7mins I opened it up and just about burned my finger on the motor. So I decided to check the temp, it WAS 161 DEGREES FARENHEIT. By the time i got my camera out it was down to 144. See pic. Is this a bad thing?
Old 04-22-2004, 09:49 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i dont think the motor is supposed to get that hot. are you using the heatsink?
NEVER UNDERESTIMATE THE POWER
Old 04-28-2004, 12:28 PM
ZipZapin's Avatar
ZipZapin ZipZapin is offline
Let The FurY Out..
Send a message via AIM to ZipZapin Send a message via Yahoo to ZipZapin
Does it evan still run? I know thast low temperature for a nitro, but a 180 E? get a heatsink and a hood scoop, you need it!
ZZ-1-Monster ZZ With Tricell.
ZZ-2-Dual Cell Eclipse.
Plow Attachment coming soon.
Old 04-29-2004, 01:34 AM
Yup it still runs fine. Brought it down to the local track. Everyone was just amazed at the acceleration. Way too much torque even with AWD and the tallest gears. The speed tops out in about 1 second at full throttle.
Too bad the RS electronics have no range. The little car could barely make it around the track. It glitched about 90% of the time.
Also ran my Mini-t with 8cells and Baja motor. Now that motor was running at a scorhin 250 degrees.
Old 04-29-2004, 09:28 AM
aperson's Avatar
take my advice, dont get them too hot. use as many heat sinks as possible. if they are getting that hot youre losing performance, and motor life.
Old 05-12-2004, 06:56 PM
jon.jon's Avatar
jon.jon jon.jon is offline
Heres my gauranteed heat problem solution on the left is 130 case I use the dremel to put vents in it, long on this side and short on the other side, with all the air moving in and out the motor doesnt really have any time to get that hot. It runs so cool you dont need a heat sink.
The middle and right are spin brush pro motors. A while back I bought a few of these because I thought it was better to have 3 motors, 1 toothbrush with 3 replacement heads, and 6 extra AA batteries to have laying around all for the same price of a regular 180 motor that I would probably have to still modify, but to find out after the motor died the brushes and the spinbrushes are paper thin, they disenegrated. Now I finally got my fets in (thanks neuro excellent mod) so I need a souped up 180 motor since the SBP brushes are not all that good I trimmed and added a xmod endcap works great so far, next will be bearings in the 180!! I dont even know its probably already been done all I can say Im making the same move.
Old 06-30-2004, 12:25 AM
color0's Avatar
color0 color0 is offline
Send a message via AIM to color0
(first reply )
so, about 180 motors in general, if you made one hot enough to fry the FETs, wouldn't it be one f***ing fast motor, while you still had plenty of torque?
Brian Ma
Greyscale Racing
Old 08-09-2004, 09:54 PM
newbitowner's Avatar
I just got a 180 motor from atomicsmods.com and they don't get hot AT ALL, but I only run 4 I-C3's. This thing has more than enough power for me.
I want to try and run a team orion stock elite motor, but I need a pinion puller. Anyone know how much these cost?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 08-10-2004, 01:50 AM
kquistorff kquistorff is offline
Send a message via AIM to kquistorff
pinion puller
i think all pullers for slot cars work, http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW ebay always has them cheap
350Z - Zero-P CF Pro Mod Chassis, Team Novak Spy ESC, GWS R-4PII/H Receiver 4CH FM 75mhz, Hitec RS-55 Steering Servo ,Team Orion Elite Stock Motor, CF Drive shaft Med. & Long, RS soft treaded tires, Wide Track BB , 4 GP 850mah battery pack, RS AWD, Futaba 3PDF Transmiter
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 11:07 PM
FOR SALE: Near Fully Upgraded XMOD $50!! RedRSX Miscellaneous Discussion 0 03-21-2004 09:16 PM
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 04:42 PM
xmod and mini x sawhit4 XMODS Mods and Projects 21 01-25-2004 02:03 PM
Xmod Corvette Project Racer240 XMODS Mods and Projects 6 12-02-2003 09:57 AM
