02-21-2004, 08:42 AM
my lift kit
hey dudes i started on a lift kit for my xmod about 2 days ago. i have finished the rear right side of the car and will finish the rear left side and start on the front today and tomorrow. if anyone is interested ill post some pics.
02-21-2004, 11:33 AM
TinyRC XModder
Let's see 'em.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-21-2004, 12:46 PM
to lift it i made longer a arms for the back and put bigger shocks. im not quite sure how im gonna do the front yet but im sure it will come to me. the problem with the front is stock the xmod has a fixed lower a arm and to lift it you need one that swings. im not sure how im going to mount a swinging a arm to the front. ill post some pics in a couple hours after i finish the rear
02-22-2004, 03:40 PM
heres the back end of the car
crap i forgot the pic
02-22-2004, 05:30 PM
In my opinion that looks somewhat too wide, making it easier to snap in half...yeah, not good. But cool.
02-22-2004, 06:59 PM
i dont think any part is gonna snap in half from any "abuse" because its not gonna be super awesome when im done. it will be slow, under powered, and wont steer well. this is mostly for looks, not function. ill probably buy a new age mod lift kit when they are for sale
02-25-2004, 10:31 PM
TinyRC Innovator
great work i always love to see other versions of my lift desingn
great work
IF YOU LIKE THIS MOD OR ANY OF MY OTHER MODS CHECK OUT OUR SITE AT
08-07-2004, 08:58 PM
Good job... Wish I would have thought of that... Well keep us up to date on how it is going...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
08-10-2004, 11:55 AM
Ferrari rox and so do i
i agree it does look like if you hit a bump it will snap in half
Skyline with RS graphics
All RS upgrdes
4.5 Stiff/front Medium/back
9 tooth drag motor
GTR Xtreme kit from cXp
Custom internal intenna
Custom lights with fogs and tailpipe
Mono-shock in rear
Red Ferrari 360 modena body in the works
08-10-2004, 04:05 PM
It does look a little flimsy but, what is it made out of? It looks like aluminum... Let us know...
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
08-10-2004, 04:38 PM
it looked flimsy when i made it but it was actually just as sturdy if not stronger than the stock setup. It was made of aluminum so if you think the a-arm would break from any abuse that i could possibly put on it then your wrong. The a-arm was connected the same way the stock one was so if that broke it wouldnt be my fault. I never finished the lift kit. I never got around to figuring out the front part.
08-14-2004, 04:35 PM
The only thing you need is som REALLY long shafts and a REALLY long tierod... Lemme know how it turns out... Dont give up yet!!!
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
08-14-2004, 05:49 PM
the almost completed shaft is already in there for mock up. basically i glued the old shaft to a plastic rod that would go into the wheel. I was going to make a mold for it later on in the project but the project was canceled before i ever got around to it. As for tie rod i guess you mean to make another attach ment point on the a arm but the xmod suspension doesnt work like that.
08-19-2004, 04:33 PM
My "lift kit"
I'm completely changing the suspension geometry, with a custom double wishbone suspension, and lego technic tires, I will have around an inch of ground clearence front and rear, 45+ degrees of articulation, yet still be stock width. I have a Ford Expedition body that is lifted too. I call it project baja. The suspension is still in the building prototype stage. A micro elite stock, lithiums, and Atomicmods.com Wide-Track Bearings are in it's future. It should destroy mini-z overlands, as I have 4WD, and they don't.
