Old 02-21-2004, 04:41 PM
Metallica88 Metallica88 is offline
6 cell, how?
hey, i dont even have my x mod yet but when i get one, this is one of the things id like to do. My ?, how do i do this? Also, is it really a good up grade or not so much? thanks in advance
Old 02-21-2004, 08:51 PM
Got 4.2 King? I do : )
if you jsut want pure speed its a great upgrade
and its easy to do, easier that swapping a motor if you know what your doing. you jsut need a soldering iron, solder, xmod, battery holder and a Knife/dremel/file.
first you make sure the batt. holder will fit under your car before you cut anything (the open holder at rs works good). next if it doesnt fit, you grind teh hell out of it to make it as small as possible. now that its small more the motorconnector above the stock batt. holder. strip all four wires and solder them together. make sure your + go to -. thats pretty much it shouldnt take long and if you shave the batt holder you shouldnt have to touch the body it should slide right on, it did on my skyline atleast
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 04:27 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 04:22 PM
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 07:42 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 11:06 AM
