Old 02-20-2004, 06:57 AM
dolfan03 dolfan03 is offline
track questions
just wondering what is the smallest track i could build indoors that will still have some fun to it?
i was thinking maybe 8 X 6 or 8 X 10? lmk what you think ,feel free to post pics of your tracks also. thanks
Old 02-20-2004, 03:31 PM
rlc77 rlc77 is offline
Hippygeek
This is my Track. It's a Wide L track but is only setup as a Wide Oval for now. It's 13' X 9' and we have a blast with it.
Xmods are cool, but Mini Z's rock
Old 02-20-2004, 03:34 PM
pretty cool , what about a 2ft lane by 10 ft long oval track ? would it be raceable w/ 2 stock xmods?
Old 02-20-2004, 06:31 PM
Hippygeek
Depends on your driving skill.
The corners would be very tight.
You would probably need the 4.5 tie rod to negotiate them.
Old 02-21-2004, 01:17 AM
spinitsidewayz!'s Avatar
boro dori style RC
the 4.5 rod would give you worse cornering. u'd need toe-out if you wanted tighter cornering. but then itd be very twitchy.
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-21-2004, 08:13 AM
Hippygeek
I think there are several people on the forum that would disagree with you on that statement.
http://tinyrc.com/forums/showthread....threadid=16445
http://tinyrc.com/forums/showthread....threadid=15576
http://tinyrc.com/forums/showthread....threadid=15227
My personal experience is that my cars turn the best with the 4.5.
Old 02-21-2004, 08:47 PM
boro dori style RC
in real cars toe in gives you stability and toe out gives you more cornering. maybe it doesnt apply to xmods, but from my experience toe in gave me understeer. ::shrug::
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-21-2004, 09:07 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
excuse my ignorence, but what are the laser pointers for??
--Chris
Aka...aero528
Old 02-22-2004, 10:18 AM
Hippygeek
It's a Lap Counter, connected to a Computer.
Old 02-22-2004, 10:26 AM
aero528's Avatar
like my dog??
ok, but how do they work that far off the ground?
--Chris
Aka...aero528
Old 02-22-2004, 10:38 AM
RC 2NR RC 2NR is offline
TinyRC XModder
In real cars it's the opposite. Toe-out is for stability, toe-in is for more responsiveness.
What software are you using?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-22-2004, 11:16 AM
Hippygeek
You put a flag on the antenna. It breaks the beam as it goes by.
Here are pics of the actual working model, and of the flags I use.
Old 02-22-2004, 11:39 AM
Hippygeek
Here is a pic of the board that is inside the pipe with the holes. It has 6 phototransistors on it but only 4 are in use. The original wiring diagram I got was for 6 cars but did not work correctly so I found another wiring diagram for a 4 car setup and it works fine.
Old 02-22-2004, 11:50 AM
Hippygeek
It's called Virtual Race System. I got it here.
http://www.i4style.co.uk/vrs/
Old 02-22-2004, 05:17 PM
boro dori style RC
if you read any automotive 101 book, its toe in for stability and toe out for more response. why would you want toe out for more cornering? because your inside wheel travels in a smaller circle then the outside wheel. toe in gives you understeer.
http://www.z31.com/alignment.shtml
http://www.yokohamatire.com/utmeasures.asp
r34 - rwd
r34 - awd
dd4 - fwd
My New track and a pic of my work area zydio ZipZaps Gallery 15 01-12-2005 04:17 PM
Track idea, comments wanted MoobY Tracks 3 12-07-2004 09:01 PM
Porta-Trax announces SuperCircuits Pro Track Kits lornecherry Bit Char-G / MicroSizers 18 04-02-2004 12:34 PM
Track layout idea Talon Bit Char-G Mods and Projects 0 12-31-2002 02:39 PM
Need help track materials.. NewbieBrigade Bit Char-G / MicroSizers 2 08-06-2002 03:18 PM
