Old 11-29-2003, 08:18 PM
Daazndood Daazndood is offline
whats a servo? does it stand for something?
Old 02-07-2004, 11:24 PM
KennyD KennyD is offline
Send a message via ICQ to KennyD Send a message via AIM to KennyD
I took the black screw out of the servo (I think thats what its called... its a little white thing that moves a yellow bar that controls your steering ). Anyways, after I removed that screw, I tried to re-align it like you said... well whenever I turned the car off then on back again, it would go back where it was... Even without the screw holding it inplace. I'm lost I just put my car back together and messed with the trimming and it's going straight enough for me Later.
Old 02-08-2004, 01:33 PM
neurokinetik's Avatar
First off, welcome to the forums.
You missed one crucial point here. When you remove the servo horn, you are supposed to power the car and controller up so that the servo centers itself. Then shut everything back off and reinstall the horn, lining it up so it is straight up and down (or as close to it as possible.) While the power is off, do not allow the servo to turn when reinstalling and lining up the horn. If you do, it won't be perfectly centered.
Old 02-08-2004, 01:38 PM
Yea, holding it still while you're trying to reinstall the black screw to the servo is hard... I think I finally got it though. Thanks for the help, I'm a retard.
Old 02-08-2004, 03:11 PM
4 Door LT1 4 Door LT1 is offline
Send a message via AIM to 4 Door LT1
my car runs straighter in reverse than it does going forward. are you guys gunning it all the way off the line? that could cause it to seem like its verring off one direction, cuz on the xmods they have a limited slip and not a very good one at that, so one tire could be spinning faster than the other. another thing that could be messing you up is maybe you have one lugnut tighter on one side than the other, mine was like that for a while. after a few other runs it started verring to the side again, so i took off the wheels, and pulled out the bearings and there was all kinds of not happy stuff in there. took it all out and both wheels rolled extremely smooth. hope this little bit of info helps.
Old 02-23-2004, 05:18 PM
meteoraclown meteoraclown is offline
a quicker way to do this is to take the servo out. in the back of it there is a black screw. take that out and GENTLY pull the servo out. This is way easier to do then taking out the whole front setup. Also if it's crooked you just GENTLY pull it out and do it again. I stripped a screw doing it the other way so this is easier.
Old 02-26-2004, 12:20 PM
teamdeadbunny's Avatar
teamdeadbunny teamdeadbunny is offline
Track Master
Mine pulls to the side as well. I tried to fix it but no luck.
When I changed the steering arm thingie, it got worse. And one of the wheels is visably off to one side.
I have ot re adjust it each time I use it butnot a huge deal.
Would be nice if there wasnt so much sloppyness in the front wheels to start i guess.
Team Dead Bunny Racing
Old 02-28-2004, 03:08 PM
codedat
One thing to do before you start is to turn the car on and off for a coupple time then turn on the TX unit then follow the steps. I notice that when the RX unit centers the servo sometimes it not exactly center. Turning on and off a coupple time will make sure it's centered.
Old 12-10-2004, 10:41 PM
da510 da510 is offline
anybody have pics so that i know what im doin?
Old 12-11-2004, 03:19 AM
I have a beach ball...
If you follow the directions TO THE LETTER, you don't need pictures. If you can't work on it near the computer, try printing them out. Since it's been awhile since I've seen this thread, I'll try to get some pics, due to the many requests for them. It might be a few days before I can get them, because I left my camera at my uncle's house at thanksgiving, and I haven't had a chance to get out there to pick it up.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 12-11-2004, 03:02 PM
Thanks, your pics would be much apprecciated.
Old 12-17-2004, 03:07 AM
Loose wheels are a very common problem with these cars. There is not a whole lot that can be done about it.
Sorry for the delay on the pics, I haven't been able to get my camera yet. I've been working 60+ hours a week at my job (retail blows) and haven't had the time.
'65 Ford Mustang
All the RS goodies
Old 12-17-2004, 10:18 PM
J-Tuner's Avatar
J-Tuner J-Tuner is offline
If you want some good instructions on aligning the steering servo and step-by-step pictures to go along just go to http://www.atomicmods.com/how_to.htm and scroll down.
Hope it helps.
I hope you like the back of my car, cause you'll be seeing it alot.
rsx to skyline VaTifosi XMODS Parts and Hop-Ups 1 11-27-2003 02:29 AM
wont go straight rx-7 bitchar-gmotors Customer Support 1 04-29-2003 04:22 PM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 11:26 PM
I got a straight bit. Deadite Bit Char-G / MicroSizers 5 10-18-2002 10:26 AM
