Old 02-06-2004, 05:35 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
just tap the breaks, while you are in the turn and the rear wheeles will break lose, but i dont think that it would work on a awd car, but it might, i am not into drifting, just nitro rc!
--Chris
Aka...aero528
Old 02-06-2004, 06:05 PM
maikeru's Avatar
maikeru maikeru is offline
DRIFT KING
Send a message via AIM to maikeru
oh there's no doubt that you can drift with RWD as i can do it with no preblems, it just takes different styles to do it, and you have to be aware of what you car is doing at the same time. all i'm saying is that AWD is easier to hold a drift so most people prefer it.
Old 02-06-2004, 09:01 PM
theMonster's Avatar
Got Brains?
drifting
Most people don't even know what real drifting is........ I'm running in a parking garage underground and I'll be going like 1/2 to 3/4 speed when I start to take a turn around a 4ft wide support-post and then I gun it full throttle while cutting the wheel 1/2-3/4 of the way I want to turn and it'll float/skid sideways around the support column. That's drifting.....most people confuse it with powersliding which is basicly doing a 180/jacknife turn. I'm also very fond of doing reversies which are reverse powerslide but starting from a dead-stop. I watched too much Dukes of Hazzard, Starskie and Hutch and Smokey and the Bandit when I was little.....
This is your brain.....
Old 02-06-2004, 09:13 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Maybe my problem is that I'm running on a smooth cocrete floor, I don't have anywhere else to run it at the moment.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-07-2004, 02:31 AM
spinitsidewayz!'s Avatar
boro dori style RC
2NR i think you should feather the throttle in the turns and countersteer earlier right when you lose traction. i drive on a concrete floor. most of the reason why you end up doing a full 180 is because of late countersteer, not enough countersteer, or too much throttle. try setting ur suspension and tires for understeer. i love my skyline and it is rwd and i plan on keeping it that way.
my set up is pretty much almost stock except for a clutch type lsd and superglued stock tires. oh and hard springs and batteries shifted to the front. the lsd keeps the car from diffing out and the rear tires from gaining too much traction.
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-07-2004, 03:51 AM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
AWD is the best drift set up i've used to date.
Old 02-07-2004, 09:52 AM
TinyRC XModder
I've tried countersteering early, late and every where in between. If I try to feather the throttle, I lose too much speed, and it basicaly becomes a powerslide. I think I just need a different surface, or AWD (if it ever becomes available ). The floor I'm running on is slippery as it is, but when I run it for a while, I get dust on the tires and the car gets really loose which gives me terrible oversteer.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-07-2004, 07:35 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
Re: drifting
i thought that a powerslide was sliding the rear end out just enough to give you a little oversteer to get around a sharp corner. am i wrong?
NEVER UNDERESTIMATE THE POWER
Old 02-07-2004, 10:18 PM
newbitowner's Avatar
add another AAA
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-09-2004, 03:40 PM
viperdout's Avatar
It's Really Fast!
The stock Stage 1 white is best for a 4 cell car. I can break the tires' grip fairly easily with 6 cells and the stage 2 blue. BTW, from what I've read, AWD is easier to drift b/c it allows you to pull out of the drift, and also allows you to aim the car easier.
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 12:01 PM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 09:53 AM
best tires xxspeednplayaxx XMODS Mods and Projects 8 01-04-2004 07:24 AM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 04:34 AM
