02-02-2004, 09:22 PM
Replies
We are always adding designs for Xmods. I will see which designs off of the site you have the link to will work on Xmods. When you start making decals in the scale that Xmod cars are in you start to lose detail but I will take some of those designs and convert them! Let me know which one you would be the most interested in and I will start there! You can take a piece of very fine sand paper (260-400 grit) and just hit the end of the DS with that. You can also reduce the diameter of the shaft by turning the shaft inside a loop of sand paper as well. The shafts are fitted for a car with bearings so they maybe tight on a bushing car. be careful when sanding you can get them too thin and make them very brittle. you should have enough material to get them to fit the bushing. You could also send it back to me and I will remachine the DS to fit a bushing instead fo a bearing at no charge. If you do that I will upgrade you to the latest design that will never break unless you step on it or something. Second question, the URL is http://xmods.decals-r-us.com. Thanks!
02-02-2004, 09:56 PM
I Shall Return!
because i dont wanna mess with the shaft (seeing how i wish to convert to bearings) ill prolly just make my bushings a little wider, as for the unbreakable version, id be happy to purchase one if this ds were to break.. again thans for the offer...
02-04-2004, 08:22 PM
Happiness is a warm gun..
Well I got a parts car that included bearings in the back and drive shaft but no bearings up front. Where would I be able to use the wider sealed bearings in the car?
02-04-2004, 09:35 PM
That's totally outrageous! The bearings we are working on will be the correct size, best quality, and shielded. And much, much cheaper. Surely no one has ever bought these from them?!
By the way, RE CF shafts:
http://tinyrc.com/shop/products.php?pid=14
02-04-2004, 11:55 PM
Any idea on when they will be ready for sale?
02-06-2004, 10:56 PM
there is some guy on eBay selling shielded xmods bearings, a whole set for 20$, they look like gold too
Xmods Skyline:
Champagne Gold paintjob
Mild bodykit w/wild spoiler
CL lights
CF centershaft
locked diff.
2nd stg. drift setup
hard slick rear/soft slick front
hard sus. rear/med sus. front
6 Cell w/IC-3's
FET upgrade
Dremel polished motor heatsink (mass mirror)
Flat black rims/chassis/front and rear plates
only thing i really needed.. and only thing i didnt buy:
AWD kit (out of stock everywhere...)
02-25-2004, 09:54 AM
not so newbie member
yeah I bought some of those sealed bearings off ebay for a little under $17. They only look gold in the picture, they are really silver. Anyway, I've had them in there for a few days now and they work great! The only thing was that since they are a little wider than the stock plastic bushings, it requires some modifying in some areas to get them to fit properly.
02-25-2004, 07:00 PM
what's the auction item # you won?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-25-2004, 08:48 PM
3176192242
just keep in mind that they are wider than the stock bushings and you'll need to do some minor modifications.
02-25-2004, 09:31 PM
They're $16 + shipping. I'd rather get the RS bearings.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-29-2004, 12:45 PM
are you missing the whole idea.. RS bearings suck in comparison. these are shielded, at almost the exact same price.
Xmods Skyline:
CL lights
CF centershaft
locked diff.
6 Cell w/IC-3's
FET upgrade
02-29-2004, 12:57 PM
but the RS bearings are easier to install
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-29-2004, 05:08 PM
0reZepyT
how? they're both bearings, it's not like you need to assemble the sealed bearings. sealed bearings install as easily as RS bearings since the only difference is they're sealed
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
02-29-2004, 06:31 PM
Actually newbitowner is kinda right. The sealed ones that I purchased off ebay are slightly thicker than the stock bushings and therfore they do require some dremel-ing to fit properly in certain spots. However, it's a pretty easy procedure. Plus the added effort is worth it to have sealed bearings in my opinion.
02-29-2004, 06:44 PM
0reZepyT
well the bearings being tested for TRC are designed to match the size of the RS bearings so no dremeling should be necessary
