10-15-2002, 09:02 PM
super accord
This is a bit char g with a clone body. Has two ni cd batteries with a switch and a 3.8 motor. what do u guys think?
10-15-2002, 09:04 PM
without body
10-15-2002, 10:24 PM
www.d1gp.com
kool switch...heh its like a switch for nitrous
10-15-2002, 11:53 PM
thats tight whats the switch for and how do u do that
10-15-2002, 11:56 PM
It's super useless!
Switch doesnt look like its attached to something. That red thing adjacent to is unfamiliar tho.
10-16-2002, 08:05 PM
i got the switch from an old toy of mine. The switch switches the car from one battery to two betteries, so i can race normal of fast.
10-18-2002, 10:38 AM
switch
where can u find that switch u used to change between 1 & 2 batteries
10-18-2002, 06:35 PM
well i got my switch from an old canned heat, but im sure u could get it from another old toy just lying around
10-21-2002, 09:59 PM
Awesome job ChArLeS, it looks great!
10-26-2002, 11:30 PM
damn...
10-28-2002, 06:41 PM
is there a site that shows how to install the switch to the two batteries?
10-30-2002, 09:44 PM
Lets Play Some Tetris
looks great try getting wings to go over your batery that would look nice and like always if its only for show coil the antenna around a pencil and c how it looks
11-14-2002, 06:43 PM
looks sick but how would I hook the switch and the battery to my car.
PROPS TO THE MICHELIN STICKER
11-14-2002, 09:08 PM
switch
__0__ (suppose to be a pic of the switch)
/ / (the 1 2 3 are suppose to be the 3 metal tabs)
1 2 3 ( the 0 on top is the red thing on the switch)
1.First get a switch similar to mine. you could get one from any old toy with a switch.
2. just like you usaully do for the first step of the two batter mod.
a. take the battery out. then set a wire touching the negative side of the battery.
b. then tape that wire to the battery good so no electricity could get through.
c. put a wire to the metal tab where the negitive part of the battery goes.( best to put it between the chasis and the tab.)
d. then put the battery back in. The wires should now be sticking out.
*******quick check*******
with all the wires sticking out, charge your car. Make sure no wires are touching each other. When u take the car off the charger, and the car responds, you probably need to put more tape on the battery. But if the car doesnt respond AFTER the charge, yout doing fine.
3.solder the first 2 wires.
a. solder the wire from the battery to the "2' part of the switch. (refer to pic)
b.next, solder the wire form the chasis tab to the "1" part of the switch.
put the switch closest to part 1 and 2. charge your car. and try to run it. if it works good job.
then put the switch on the other side. If it DOESNT work, god job.
more instructions later
11-14-2002, 09:10 PM
here is the pic the first one got messed up.
__0__
1 2 3
