Go Back   TinyRC.com > 1/43 and Smaller > SuperSlicks > SuperSlicks Gallery
Old 02-02-2004, 08:06 PM
charliebrown's Avatar
My painted Skyline.
Well, it's not much.
Just a dirty demolition derby car.
Chuckster...
Old 02-02-2004, 08:07 PM
Here's another view.
Chuckster...
Old 02-02-2004, 08:08 PM
Another picture.
Chuckster...
Old 02-02-2004, 08:09 PM
And another....
Chuckster...
Old 02-02-2004, 08:10 PM
Another view. (Last one)
Chuckster...
Old 02-02-2004, 09:21 PM
Rotary Freak's Avatar
Rotary Freak Rotary Freak is offline
Send a message via AIM to Rotary Freak
Not bad, its an interesting idea and paint app to say the least. Which Skyline did it used to be and what paint did you use on it?
I wish my Land Rover was a rotary
Old 02-03-2004, 11:56 AM
It used to be the skyline shell that came in the starter kit, 49 mhz blue skyline. I didn't like the dark blue color, so I bought some cans and decided to spray paint it. It's Testors Spray Paint, I believe. I used the light blue color, with white clear coat.
Chuckster...
Old 02-04-2004, 10:57 PM
No primer? Just sprayed and clearcoated?
Old 02-05-2004, 02:52 PM
Yup....I cleaned the body thoroughly under hot water (but I did it with the masking tape on, so that must have explained the tape coming off the windows a little. But, after putting on the tape, some of the oils from your hand may come on the body, preventing the paint from sticking.) On SuperSlick and BCG/MS/ZZ bodies, you don't need to use primer, but I hear that Xmods and Mini-Z Bodies are a different story.) I think I need to use a different masking tape, I just used ordinary, plain old masking tape.
Chuckster...
Old 02-29-2004, 10:15 AM
....Ok, so any more opinions????
Old 08-26-2004, 06:41 PM
Originally posted by jmillsrx7
I woulda tried taping off the lights etc...
Bit late there aren'tcha?
Chuckster...
Old 11-13-2004, 09:02 PM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
Chuckster...
I've used primer on BCG/MS bodies as well as Mini Z bodies. I think on ether one you can get away with no primer. I just use the primer because it helps the paint stick better and to seal the surface as well. Just on a BCG/MS I try to lay the primer as thin as I can, just one or two quick coats. And on Mini Z's I lay it on about three coats, so I can sand it smoother.
The only RS car bodies that I worked with are the cheaper RC cars and I've had all kinds of problems with painting those (not XMODS or ZipZaps), like the paint attacking the plastic. I have a few that look like a road map. And yes I used primer to keep that from happening, it still did it.
Old 03-17-2005, 06:51 AM
rabatt
masking
i got a yelow skyline and didnt like th color so igot a tin of metalik blue model paint and masked of windows lights gt-r badges and a strip slightly 2 1 side, gave it 2 coats and it looks great.
PAINTED Skyline lckyrocket XMODS Mods and Projects 30 11-28-2004 10:57 PM
My CHAMELEON PAINTED SKYLINE!!!!!! XMODSaretheBEST XMODS Gallery 10 02-12-2004 10:25 PM
Better pics of my Chameleon Painted Skyline!!! XMODSaretheBEST XMODS Gallery 17 02-11-2004 11:00 PM
Painted Skyline with Roof Scoop scorpiomjk XMODS 29 12-25-2003 07:36 AM
I Finally Finished My Custom Painted Skyline!!!! blacksabbath070 Bit Char-G Gallery 7 07-19-2003 12:16 AM
