02-02-2004, 08:06 PM
My painted Skyline.
Well, it's not much.
Just a dirty demolition derby car.
Chuckster...
02-02-2004, 08:07 PM
Here's another view.
Chuckster...
02-02-2004, 08:08 PM
Another picture.
Chuckster...
02-02-2004, 08:09 PM
And another....
Chuckster...
02-02-2004, 08:10 PM
Another view.  (Last one)
Chuckster...
02-02-2004, 09:21 PM
Not bad, its an interesting idea and paint app to say the least. Which Skyline did it used to be and what paint did you use on it?
I wish my Land Rover was a rotary
02-03-2004, 11:56 AM
It used to be the skyline shell that came in the starter kit, 49 mhz blue skyline. I didn't like the dark blue color, so I bought some cans and decided to spray paint it. It's Testors Spray Paint, I believe. I used the light blue color, with white clear coat.
Chuckster...
02-04-2004, 10:57 PM
No primer? Just sprayed and clearcoated?
02-05-2004, 02:52 PM
Yup....I cleaned the body thoroughly under hot water (but I did it with the masking tape on, so that must have explained the tape coming off the windows a little.  But, after putting on the tape, some of the oils from your hand may come on the body, preventing the paint from sticking.) On SuperSlick and BCG/MS/ZZ bodies, you don't need to use primer, but I hear that Xmods and Mini-Z Bodies are a different story.) I think I need to use a different masking tape, I just used ordinary, plain old masking tape.
Chuckster...
02-29-2004, 10:15 AM
....Ok, so any more opinions????
08-26-2004, 06:41 PM
Originally posted by jmillsrx7
I woulda tried taping off the lights etc...
Bit late there aren'tcha?
Chuckster...
11-13-2004, 09:02 PM
Thrasher
Chuckster...
I've used primer on BCG/MS bodies as well as Mini Z bodies. I think on ether one you can get away with no primer. I just use the primer because it helps the paint stick better and to seal the surface as well. Just on a BCG/MS I try to lay the primer as thin as I can, just one or two quick coats. And on Mini Z's I lay it on about three coats, so I can sand it smoother.
The only RS car bodies that I worked with are the cheaper RC cars and I've had all kinds of problems with painting those (not XMODS or ZipZaps), like the paint attacking the plastic. I have a few that look like a road map. And yes I used primer to keep that from happening, it still did it.
03-17-2005, 06:51 AM
masking
i got a yelow skyline and didnt like th color so igot a tin of metalik blue model paint and masked of windows lights gt-r badges and a strip slightly 2 1 side, gave it 2 coats and it looks great.
