01-04-2004, 12:27 PM
Mods For New-bes(and advanced)
I think we should start out with simple or quick mods for n00bs that are not ready to move on to bigger mods list your mods
Well i'll start ou with a quick mod....
window tinting-simply take a peice of electrical tape and cover the window from the inside or else it looks stupid
here is a pic of what a tinted window looks like
(either that is tinted windows but if its not thats what it looks like
thanks to TemjinNeo78 for the pic
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
01-04-2004, 07:32 PM
CMON ADD ALL OF YOUR MODS FOR THE NEW-BES
aNOTHER IS TO TAKE TAKE OFF YOUR BODY THE THE CLEAR PLATE THEN UNTIE YOUR THE NOT IN YOUR ANTENNA
blue RSX
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
white rims
metal lugnuts
mini-z tires
01-04-2004, 08:38 PM
Redneck Drifter
there has already been so many of these
01-05-2004, 05:20 PM
but we could make this a sticky and have it a really big one
blue RSX
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
white rims
metal lugnuts
mini-z tires
01-28-2004, 11:13 PM
Hardcore Otaku
Okay, err, xmodsman, howabout... The...  Yeah, just get a dremel and cut slots above the stock noes but make sure it fis afterwards. Or glue pieces of packaging plasic to the sides/bumpers to make them look like sideskirts, sand well, paint, voila...  put in another bit battery, wired in series... how easy do you want it?You know what, just go to rcmod. They have a lot of easy and harder mods, step by step processes, some for xmods too
01-31-2004, 08:18 AM
ZZ wheel Swap
Rear-Replace axle with ZZ axle
Front-Take off the clear PCB cover, and Lift the PCB board (Not too much, you don't want to break those steering wires, trust me!). Right underneath the front of the PCB board is a small screw, unscrew it. When it is unscrewed, take the front cover off the car (this may be somewhat tricky, because the cover also latches in the front of the car, so you have to pull back and then up). When you get under it, there should be three parts, 2 knuckles, and a magnet-holder thingy that connects to the top of the knuckles. Pull those three parts out, noting the direction the white part of the knuckles are pointing. Open your ZZ car with the same procedure, and remove the wheels/knuckles. Replace the Bit char-G knuckles with the ZZ ones, and put everything back together, being sure to line everything up where they go into holes. NOTE: you may have to Dremel out behing the wheel because of the added diameter of the ZZ wheelset, or else the wheels may bind when they turn sharply. You may also need to dremel out the wheelwells on certain cars, because they may only be large enough for the small Bit wheelset
These instructions can be reversed if you want to give a ZZ a Bit Char-G wheelset too.
As long as these instuctions are, in my opinion this is the easiest visual appearance mod besides swapping bodies. I did this mod and it only took ~5 minutes.
-Micro
