01-30-2004, 09:55 PM
("\(0.o)/") Rawr!
water dipped Sb?
I read on Xmodworld that a water dipped sb is fast.... is this true?
Xmod Parts Help
01-31-2004, 12:13 AM
I tried the water break-in a couple of times, and for the most part, the results were very favorable. I used it on a couple of stage 1 motors.
01-31-2004, 01:24 AM
can i dip my RS motor?
how would it be done?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-31-2004, 02:07 AM
Got Mini-z?
this was taking from minizworld.com so don't give me all the credit...
Breaking in a new motor (or new brushes)
Right then :-) Get yourself a glass of water, an aaa battery box with two batteries in it, some sticky tape, a little bearing oil, and some motor spray.
Submerge the motor in the water, and tape the wires to the side of the glass so that the motor is freely suspended, not touching the sides. Connect the motor to the battery box such that it spins the same way that it will in the mini Z. Leave it running for 5 minutes or so (the water usually turns dark gray), remove the power, take the motor out of the water, spray liberally with motor spray, leave to dry for 20 minutes, oil the bearings, then put it in your Z - eh Viola! :-)
Why use water? It provides a load whilst running in, it removes air, so prevents a lot of the arcing between the comm and brushes, and finally it keeps the motor cool under load.
Generally, with the water method, most people run in their motors at about half their normal running voltage - So, we run our with four AAAs normally, so run it in with 2 AAAs.
This tip provided by Rob D. in the UK.
01-31-2004, 03:27 AM
Happiness is a warm gun..
This will make a noticeable difference in your engine. I usually break it in for at least 10 minutes and pull it out of the water once or twice during the 10. Most lubricants will work well when you lube it at the end. The higher quality the lube the better, I use slick 50.
01-31-2004, 09:42 AM
slick 50 1 lube?
01-31-2004, 01:56 PM
That's the stuff. Part of its fuction is to displace water in the motor and the other is to lubricate.
02-01-2004, 02:58 PM
("\(0.o)/") Rawr!
so lemme see, all i got to do is let the motor run in a glass of water for like...15mins then lubricate it with something? can i use WD-40? o yea how much of the motor do i dip in it? the whole thing or half of it? same with the lubrication whole or half?
Xmod Parts Help
02-01-2004, 04:26 PM
Completely submerge it, WD40 is good. Pull it out once or twice during the 15 and then spray the inside of the motor down using the ports on the plastic end.
02-01-2004, 05:43 PM
("\(0.o)/") Rawr!
so i'm spraying the inside right, from the back? not the exterior
Xmod Parts Help
02-02-2004, 12:16 AM
Right, inside only, wipe off the out side when done
02-02-2004, 01:29 AM
("\(0.o)/") Rawr!
ok last question (hopefully) what should i expect performance wise more speed, torque, or both?
Xmod Parts Help
02-02-2004, 09:15 AM
both along with it being quieter
02-02-2004, 09:52 AM
("\(0.o)/") Rawr!
 sweeet!!! thanks!!!!
Xmod Parts Help
02-02-2004, 05:24 PM
Got Mini-z?
i just water dipped my S2 road motor... as far as i know it sounds faster and is alot quieter.. i didn't put it in my xmod to try but i will soon..its like a blender inside the water when you take it out then but it back in...
