01-20-2004, 03:22 PM
I Shall Return!
yea thanks that what i was figuring, i plan to take off this motor for now until i can get that fet mod dont, and possibly get a c-f chassis. whats motors would you recomend for me to put in my xmod, like i said i want tiring spinning torque as well as 20 mph+ top speed. ill prolly go down to my lhs this friday so i wanna know what motors to look for.
01-20-2004, 04:24 PM
I haven't found an off-the-shelf motor that will give you good torque and that kind of top end. (I don't consider NML an "off-the-shelf" motor) Maybe a PN Racing S03, but again, that requires FETs. None of the available 180s are that fast without wind reduction or a complete rewind.
01-20-2004, 04:27 PM
I Shall Return!
so say i bought a 180can team orion stock motor, and took off about 15 winds, what kind of performance could i expect?
- what kind of performance does the s03 give,
- how much dose it cost?
thnx again
01-21-2004, 03:24 PM
I Shall Return!
hey neuro for a motor, i was thinkig along the lines of PN s03 motor or the Mini-ZRacer.com Super High Performance BB Motor Z-130-S-BB, please dont consider this a noob question, more so as an opinion, in your opinion which gives beter torque and power? also which is compadable with a 6cell upgrade
please note i will be purchasing new fets to upgrade as well...
01-21-2004, 04:44 PM
The S03 is a favorite of the Mini-z guys, and for good reason. My own experiments have pointed me pretty much to the same thing. 35-39 turns, with thin Neo magnets. The Mini-z guys all require FET upgrades to run it, I think it's an iffy proposition in a stock XMod. I bet a double stack of the stock FETs could handle it fine, though. Just don't put a big pinion on it. 9 tooth max.
I don't know any specs on that particular Mini-Zracer.com motor. I don't recommend the Z-130-A-BB for XMods though. It was downright slow in these cars.
01-21-2004, 07:39 PM
I Shall Return!
lol i know this sounds insane, but whats if i was to put my 12t pininon that i have? obviously the current draw would be through the roof but im pretty sure ill be getting some powerful fets ne wayz, o yea with 12T how badly would my torque suffer? i know this is all farfetch, but i want to beable to spin tires, as well as have a 25 mph top speed on stock batts
o yea im very much interested in your speed checker, where did you buy it from i saw one for 25 bux at a site that sells the s03 for around 28 bux
01-22-2004, 08:36 PM
I Shall Return!
hmmm
01-28-2004, 08:38 PM
SHYMERLOO!!!!
i know i asked this a whole bunch of tymes but HOW DO U GET THE FREAKIN PINION OFF?????!?!???!
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
01-29-2004, 02:30 PM
pinion puller. end of story.
2003 RSX
S2 SB Hybrid, 11t, minus 10 winds, timing advanced 18 degrees
14G Wiring (craziness)
AWD
Hard Coils Front
Soft/Hard coils rear
Custom aluminum front upper deck
wheel+tire upgrade, currently soft tread rear, soft slicks front
Lightened body
Lightened chassis
Body Kit (not in use)
01-29-2004, 03:47 PM
SHYMERLOO!!!!
besides dat..... i only got like $2 left.... allowance next month.... sux dont it...
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
01-29-2004, 05:39 PM
I Shall Return!
u can make a pinion puller
take like 10 soda cans, and cut away the aluminum, glue all the sheets together and bend in into a giant "U" then use a scissor or drill (with small bit) and make a slit on one of the "U's" arms (for the motor) and then put a tiny screw on the other arm of the U, put a motor in and tire black tape arount it to keep its shape, then use it like a pinion puller
or an easier appreoach would be to take the motor in question, wrap with many layers of Al, then take a lighter and hold it their for like 15 min... the Al will keep your motor safe... btw PLEASE USE PLIARS TO HOLD AND REMOVE THE PINION... i cant stress this enough!
01-29-2004, 06:18 PM
0reZepyT
aluminum is gonna conduct the heat rather than shield it. that's why they use it to cool processors.
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
01-30-2004, 03:32 PM
I Shall Return!
yea but it works, put AL pver paper, and put a flame to the AL... the paper wont light because the AL blocks the heat, im not screwin with you, try it
