Old 01-28-2004, 09:20 AM
geofroley's Avatar
R34 Skyline is God
Well first off, what are the comms?
My Bit: Phast motor (Orange)
Old 01-28-2004, 09:35 AM
Its the metal tabs that the wires are connected to, there are three of them.
Old 01-28-2004, 09:43 AM
geofroley's Avatar
R34 Skyline is God
Ok I think I got some of this down.
Solder one end of the wire to a comm
Wrap wire around one section
Solder wire to next comm
Wrap wire
And so on.
Old 01-28-2004, 04:06 PM
Yeah, just remember the order of winding...
Start with a comm, solder the wire, wind it around the leg to the right in a counterclockwise fashion, and bring the wire to the next comm to the right of the leg you were winding and keep repeating that process until you are finished.
Thats the order for 130s, 180s are slightly different.
Old 01-28-2004, 05:59 PM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
I'm confused ... do you put the total number of winds on one leg, then move to the next leg?
Almost sounds like you are doing the whole motor with one continuous wire too. Is that right?
I may open up another motor to put in some more SB magnets tonight. I'll have to take a closer look at how it's wound... I'd love to get into this winding stuff, but dont wanna screw jank up
Sliver Xmods Skyline
SB hybrid S1 drift motor - Yay doughnuts!
Old 01-28-2004, 08:09 PM
geofroley's Avatar
R34 Skyline is God
You solder the wire to each comm, right?
Old 01-31-2004, 03:00 PM
If you are winding from scratch, use one wire.
You will be soldering wire to each comm, however, it may be the same wire.
If you are just doing the easy "cut-n-paste" method to unwind a few turns on the legs. You will have cut 1 wire into 3, but the connection is still there when you solder the wires back to the comms.
Old 01-31-2004, 04:37 PM
demon's Avatar
demon demon is offline
just dont loose count of the winds,i did that plenty of times,then had to unwind it
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 12:38 AM
quick motor winding question Lucid Dreams XMODS 1 12-24-2003 11:01 PM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
Question about fullsize wheels set Mod..? SPEED QFM Racing Customer Support 5 09-25-2002 11:26 AM
