Old 01-18-2004, 01:02 AM
BryceOwen BryceOwen is offline
Max power...
I was wondering if anyone knew how much voltage and current the servo board can handle... I have an HPI MMM that I was hoping I could use. I know I won't be able to feed the power the motor requires through the "ESC", but if I knew it's limitations, I can plan around it.
Old 01-18-2004, 01:03 PM
oldtamiyaphile oldtamiyaphile is offline
Has anyone over come the problem of limited throttle range?
I mean, it only takes until about 1/4 stick to reach full throttle, makes trucks very jerky to drive. I'd like to be able to reach full throttle at around 3/4 stick. Other than using a TX with EPA (sorry but my good TX stays with my heli and possibly other aircraft), any ideas?
no spam messaging allowed in this space or home page spaces
Old 01-18-2004, 01:41 PM
Thorsten Thorsten is offline
Hi,
thats the reason for a good speedcontroler instead of a servocontroler;-)
In a servo you must have a short time of reaction. I think you dont want to wait some seconds until the servo reaches his position.
To do this, the servo controler have a small 0-point and fullspeed at 1/4 stick.
I dont know a solution to modifie the servocontroler.
But I have a little circuit on my website (www.mikromodell.de) . This is a cheap speedcontroler with "normal" ranges.
best regards
Thorsten
Old 01-23-2004, 04:10 PM
cheesehead cheesehead is offline
the ICS-50 should work if you use enough cells. The voltage cutoff is an annoyance, though.
The Pixie 7p is a better option, with a max. 7 amp draw and all the goodies, including adjustable cutoff. It should work nicely.
I personally think the ICS is a good idea, as with a cheap Li-Ion pack your TTTT will go for a looooooooooooong time
Old 05-25-2004, 11:59 PM
bluemonster bluemonster is offline
So am I to understand that I could use a servo with a larger motor in place as a speed control? I am also building a 1/24 Monster Truck/Rock Crawler, and this would be a very economical and lightweight answer!
I would be running a Speed 300, is that going to kill my servo "speed controller"? I imagine in a rock crawling situation, running 6 volts and a Speed 300, the amps might be a bit much for a servo to handle, or is that guess an incorrect one?
Old 05-26-2004, 12:21 AM
Overlander's Avatar
Overlander Overlander is offline
Overworked
Yes a 300 sise motor will fry most servo board ESCs. You could try a large 1/4 scale servo but at that cost you might as well buy a standard micro ESC. There are many 1/24th and 1/18th RC models out there these days. Micro ESCs are easy to come by at that size.
IMO, a 300 motor is way too much for a 1/24 rock crawler anyway.
_______________
I just like to build.
Speed & Steering Control hschnark Bit Char-G / MicroSizers 2 03-09-2006 05:39 PM
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 06:15 PM
New Micro Servo! Smallest in the World! Overlander TTTT 7 03-02-2003 12:27 PM
Servo PCB as Prop Speed controller! scottyboyfun Bit Char-G / MicroSizers 2 01-03-2003 08:51 AM
speed control? go_zz_go ZipZaps 12 11-26-2002 07:13 PM
