Old 01-15-2004, 09:48 PM
census007's Avatar
census007 census007 is offline
Drift withit
is 12 volt to much to run leds
i want to run 8 leds off a little 12v battery. will the leds burn out
A man that has made no mistake, has made nothing at all, and i have made alot.
White Supra
awd
C-logic kit
Stage 2 Motor Kit
Body Kit
Spin Brush
Old 01-15-2004, 11:00 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
depends on what the led's are rated for and how well it was manufactured. i've had radioshack brand 2 volt 5mm clear yellow (more amber than yellow) led's burnout at like 2.5 volts. the 5mm 2600mcd clear blue leds have survived 12 volts even though they're rated for like 3.7 volts or something like that
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-16-2004, 07:13 PM
theMonster's Avatar
Got Brains?
car leds
Car (real car) leds run off of 12V, so I'm sure you could use those. Maybe RS will have some 12V in stock?
This is your brain.....
Old 01-17-2004, 10:06 AM
Short1mgb's Avatar
Short1mgb Short1mgb is offline
Lets Play Some Tetris
12 volt will burn the leds rear car leds are built with resistors
Alternate Flashing LED's Stormvet XMODS Mods and Projects 46 04-21-2004 10:53 PM
My calculator has LEDs in it! xatu Bit Char-G Mods and Projects 16 07-12-2003 12:00 AM
6 Volt mod test with video-Any ideas? jpaustin Bit Char-G Mods and Projects 9 01-30-2003 03:43 AM
need help w/ LEDs plz... actofgod Bit Char-G Mods and Projects 4 10-01-2002 06:45 PM
Different Types of LED's Broom Bit Char-G Mods and Projects 5 09-10-2002 03:58 AM
