Old 01-14-2004, 07:01 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
Arrow How To Make Your Own Antenna With Pictures!!!!
This takes about 5 minutes tops.
1.take a peice of thin copper wire.
2. strip the ends about an inch off of EACH SIDE.
3. Curl one end around the RS screwdriver. It doesnt matter how many times you wrap it just make sure the screw is able to screw into the hole.
4. put it on and fly away.
P.S. I would apprechiate if BC could put this in his FAQ page.
thanks.....please
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 01-14-2004, 07:33 PM
theMonster's Avatar
Got Brains?
blurry
Your pics are real blurry, is the decks on your car aluminum or just painted blue?
p.s. to all: you have to use the stiff copper wire, not the floppy bendy kind like speaker wire.
This is your brain.....
Old 01-15-2004, 12:28 PM
xmodsman's Avatar
actually i did use the thin wire and its imposible to wrap it around your screwdriver and then put it on.
sorry about the blurry pics guys!
blue RSX
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
white rims
metal lugnuts
mini-z tires
Old 01-15-2004, 01:02 PM
charliebrown's Avatar
You might want to use guitar string lie ph2t did. It will be tensile, so it springs right back to an erect position after being hit by something.
Like he said....Cat5 is for chumps!
Chuckster...
Old 01-16-2004, 01:58 AM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Send a message via AIM to Shiporu Send a message via Yahoo to Shiporu
Remote Attena!!!!
xmodsman, can you make a tutorial on making a remote attenna for us? That would be great!!!
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
Old 01-16-2004, 04:37 PM
xmodsman's Avatar
im 11 but i guess i could try to figure out how to make one i guess
blue RSX
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
white rims
metal lugnuts
mini-z tires
Old 01-16-2004, 07:17 PM
theMonster's Avatar
Got Brains?
great idea
Great idea Charlie Brown!!! I didn't think of guitar wire! A top E string or a B string would probably work great!!! You'd probably need some tin-snips to cut it though!
Old 01-17-2004, 03:06 AM
microINNOVATION's Avatar
microINNOVATION microINNOVATION is offline
TinyRC Innovator
Send a message via AIM to microINNOVATION
yeah good mod but ill tell you what will work better go pick you up a microsizer controller and take the antenna out of it curl up one end and screw it in longer and stffer great range too
IF YOU LIKE THIS MOD OR ANY OF MY OTHER MODS CHECK OUT OUR SITE AT
Old 01-18-2004, 10:48 AM
Re: great idea
Umm.....I didn't think of it....Give all your thanks to ph2t, (what kind of name is that anyways?) 'twas him who brought upon thee the savior of antenna.
Chuckster...
Track and Antenna Mod pics Robotguy ZipZaps SE 2 04-12-2005 02:01 PM
I Have An H-bridge Install Tutorial...need Pics Authorized Jshwaa XMODS Mods and Projects 13 11-08-2004 06:43 AM
The perfect antenna Mod...for anyone Johnaten ZipZaps 3 11-10-2002 10:32 PM
antenna idea, bummer it doesn't work... john ZipZaps 5 11-07-2002 10:17 AM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 12:13 PM
