01-13-2004, 03:26 PM
I Shall Return!
Phyco reception
well today i brought my xmod to school and was drift racing my friend in home room around the desks... and well he took a wide drift and ending up sandwhiching me into the wall, my car then fliped over... no biggy it still worked fine and i ended up winning, The problems began when i brought my car close to me IT STOPs it dosen't respond to my controller if my xmod is less than 3 feet away from the controller, whats up with that?.. otherwise, if its far from me its fine, any ideas on a quick fix solution (besides exchanging) and i mean quick cause i got a rematch tomm.
so please help out here
-fellow xmodder
01-13-2004, 03:55 PM
Got Brains?
hehe
Stand 3 feet away from the x-mod at all times...... no seriously, that sounds weird. I almost bet that there is some interference going on from your friend's car. Was his on at the time? Does it work when he's not around? I know that my Monster goes nutty whenever the computer is turned on, it's way too big to run indoors anyway.
This is your brain.....
01-13-2004, 04:05 PM
I Shall Return!
my xmod worked fine until i got hit, i used to get reception like a champ in my house, but now this bolony happens in my house with same condition (i.e. comp and tv are on) so ive ruled interfereence out, i also changed the Tx battery and recharged the car batts... no luck, please help
01-13-2004, 04:08 PM
I Shall Return!
no no my car got reception like a champ in my house even with a tv, computer and microwave on... so ive ruled out interference, it was also good at school until i was hit. so i got no clue, i replaced the controller's battery and rechaged my cars batts... no luck  please help!
01-13-2004, 04:14 PM
try changing the crystals in the car. some times the crystals crack and do weird things
01-13-2004, 04:51 PM
I Shall Return!
did, beleive me ive tried every single thing except crack open the pcb... i also called rat shack and their like "wow, of all xmod cases ive heard this has gotta be the first, you should call our help line" the help line woman asked "did you change the batteries?" but i calmly replied "yea ive tried EVERYTHING and notting works" she checked her data base and got no simlar cases, her only idea is that the controler is over shooting the signal? da heck/ so if so what would you guys recomend
01-13-2004, 05:21 PM
I Shall Return!
comon you guys, help!!! any ideas please, im serious, i fliped my xmod over and it workes until i come within like 3 ft its frikin LAME!!! please help, if you read this please help!!!
01-13-2004, 05:47 PM
mine did the same thing when i got clost to my friends remote or car but i would check the caps on the motor the are filters for interference but i n my mind it almost sounds like a crystal prob but you say you changed the crystals hmmmm that is really strange does it go nutts or just stop if it goes nutts it would be signal interference but if it stops for no reason thats really strange three feet huh hmmm what car do you have or what frequency do you have in the car becausee the length of the antenna actuall has some stuff to do with fm reception with my experience in electronics the only other thing i can think of is look at the pc board and check all the solder joints maybe something got knocked loose but i really have no clue man sorry i can't help if i think of any thing i will let ya know
Nissan Racing
KA24E
7500 RPM
280 HP
270FT-lbs
01-13-2004, 06:03 PM
I Shall Return!
i like the idea for the motor caps, btw with the crystals i meant to say i took them out and cleaned them then put them back in... tomm im off to r.s. to show them this and experiment with the crystals...
01-13-2004, 07:25 PM
you probably got some type of interferance from the electricity in the school I drifted in a schools halls after hours and still got bad reception in certain spots.
Sinistar
question #6 is now ready out of the
toaster and has popped up for you.
01-13-2004, 08:03 PM
I Shall Return!
i know thats what i figured cause my school has a bunch of wireless access points, but what stumped me was im getting the same symptoms at home. but yesterday it was fine so go figure. thats the puzzle lol
01-14-2004, 12:00 AM
have you tried exchanging it?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-14-2004, 06:20 PM
I Shall Return!
i dont want to tho... any way as for an update, i checked the motor, both the resistor and capacitor are soldered good and then went to rat shack to show them... i tested every possible combo to make sure its my pcb and nothing else...
r.s. demo red supra (same as mine) - works fine
new crystals in my car - same symtoms
my crystals in r.s. demo car - works fine
demo car controller and my car - same symtoms
my controller with demo car - works fine
and so i now know its my pcb...the reason i dont wish to exchange, is id rather get a replacement pcb for experimentation, if some1 could post a pic of a normal looking pcb ill open mine up and compare the two for shorts or misconnections... please help this is really frusterating!!
01-14-2004, 06:29 PM
Got Brains?
well....
If you have a transistor or capacitor or other chip burned out on the board, then you probably won't be able to tell with the naked eye what went wrong, unless it just decided to melt or blow and left burn marks around it, in which case you probably should've seen a little smoke puff and DEFINATELY should've smelled ozone (if you've never smelled a burning chip's ozone, it's terrible and will choke you QUICK).
01-15-2004, 05:36 AM
I Shall Return!
well i dunno, all i know is all this happened after my friend rammed me, so im hoping that jus a component broke loose... its funny if you saw me drive, i have to keep running from my xmod, otherwise it dies and hits something, i already broke the front bpdy clip (an easiy fix tho)
