Old 01-04-2004, 03:50 PM
rsxracer90 rsxracer90 is offline
Send a message via AIM to rsxracer90
advise please
man i jus got my first xmod (acura rsx) right and started to put it together and lost one of the pieaces. that black little thing that goes over ur wheel. LOST IT! now the wheel keeps comin off. after that i decided to color my rsx. went into my garage to spray paint it and taped off the windows and head/tail lights. next day came back to it and the crap bleed throw the tape. i looked at the can it said "X-O RUST prevents rust!" should i just get another xmod or what. need help
Old 01-04-2004, 04:22 PM
93Supra0wner 93Supra0wner is offline
well first about the wheel nut.....just buy the wheel upgrade or foam wheel set they come with tons of wheel nuts...and if you not happy with the way the body looks or dont want to take time and give it and acid bath they sell new bodies for like 10 bux shipped. Just check cj's faq for details
Old 01-04-2004, 06:03 PM
acid bath? i dout my parents would let me do that. and i lost my plastic light thing and my back one is lost to should i jus buy a whole new one help
Old 01-04-2004, 07:48 PM
RC 2NR RC 2NR is offline
TinyRC XModder
My kit came with six lug nuts.
Old 01-04-2004, 08:16 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
The car comes with 2 extra wheel lugs. You ger 6 wheel lugs with the foam tire upgrade, and you get some wheel lugs with the tool kit. So I am guessing that wheel lugs are the biggest things to get lost.
I read somwhere in this forum of someone getting a small assorted metal nut thing from RS and found some that fit. You could try that.
Old 01-04-2004, 11:03 PM
Jofir Jofir is offline
Send a message via ICQ to Jofir
dude how did you lose all these things???
Old 01-05-2004, 04:21 PM
i hav no friggin clue. i was racin it out side one day and i guess the black little part flew off and i cant find it now. and i wheel is lost to. i was not very responsible at the moment. but when i get my new rsx this weekend, ill make sure i will not loose any parts. im goin to paint it a candy apple metalic red, or some other red shade in metilic. ill post a pic of it when i get my new comp hooked up.
Old 01-05-2004, 07:00 PM
tavisjohn's Avatar
RC Tinkerer
OK I have found an easy solution!
Go to Radio Shack and purchase part # 63-3017 It is only $1.99. What it is, is a pack of 40 machine Hex Nuts. The threads are the SAME as the wheel studs! You cannot use the X-Mod hex tool to mount them, but a pair of tweesers or needle nose pliers work just fine. Or you can use 2 nuts (They will fit) and lock them together. Then you will not have to worry about any tires falling off unless you unlock the nuts.
Old 01-08-2004, 06:58 PM
adiosk8r13 adiosk8r13 is offline
im capital 1"s CE NO!!!
Lightbulb
magnetize all of your extra parts and stick them to something metal that way you will know were your extra parts are and they wont get lost
Old 01-08-2004, 08:34 PM
tavisjohn's Avatar
RC Tinkerer
How do you magnitize the plastic wheel nuts?
Need advise MadScott ZipZaps 5 03-18-2003 06:11 PM
