01-03-2004, 07:27 PM
X-mod Innovator
'Idea' - High Flow Cool Air System
ok here's my cool air flow system theorem
I planned on molding a working roof scoop on top of my car
then buying the smallest labtop fan that exists and mount it under the roof scoop blowing cool air on the engine
keeping your engine cool but will require a higher voltage mod or
its own battery sadly
any comments or suggestions feel free
i gots tons of crazy ideas....this is just one
++ Project X-mod 2006 ++
X-mod EVO with CVT tranny!
01-03-2004, 07:31 PM
I'm not a pyro, really.
ive been thinking about that too but i was gonna use the front grilles instead. or put some slots in my hood and use one of the fans that go into a PCI space. (not actually plugs into the motherboard just to the power supply.)
NEVER UNDERESTIMATE THE POWER
Redneck Drifter
sounds good..i looked at a little cpu fan a RS and it was almost $20...i couldn't believe it
01-03-2004, 07:39 PM
fortunately i got mine for free. my aunt used to work at seimens in TN and we got a few free computers. when we were haveing the power outages we had some brown outs in central NY the one that was 5 yrs old got fried. oh well it got put out of its misery. damn Mechwarrior 3 wouldnt even play right on it.
01-03-2004, 07:41 PM
X-mod Innovator
will it fit in an x-mod and can u give me some info on this fan i am trying to find a small one to buy now as i write this reply. can u give me like a serial number or anything about it?
01-03-2004, 07:42 PM
smallest fan i found in RS was about 2" and wouldn't fit
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
01-03-2004, 07:50 PM
sorry Bleek i dont have any info other than it was at Best Buy. but now that i think of it, it was too big to fit under the hood too. it might fit under the "cab" with a roof scoop and have it blow air over the motor sorry. or just do the roof scoop but without the fan. put the scoop on and mold an air canal that goes over the heat sink and put an exhaust port where the liscence plate goes.
EDIT: ohh i found some LED fans. what about them? oh yea found the fan too Antec Blower Fan and it def. wont fit. 4.5" x 3.6" x 0.85" little too big?
01-03-2004, 08:06 PM
X-mod Innovator
sounds like a good idea but i was thinking more like a 1 inch diameter fan i once saw in an older laptop or a fan like these
http://www.coolerguys.com/productsli...categoryID=145
01-03-2004, 08:16 PM
i have couple of fans that are about 2" and 3 1/4" . there 12v and can run off of 18v the 2" will work. it equates to 50mm. 80mm is 15mm to big. but either way the light kit will probably need to be removed.
01-03-2004, 08:48 PM
Cheese Ninja
I'd love to rig a liquid-cooling system inside one
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
01-03-2004, 08:55 PM
you'd either need a nitro engine running a water pump or have it pluged into the wall while driving it. or ive heard about a mat that charges cell phones without contacts. buy a lot of those to make a place to drive and you could have the electric pump running.
01-03-2004, 09:10 PM
Bleek,
I have sent you an email concerning your signature. Could you please shorten it up a little bit, it's a little too long.
Thank you.
01-03-2004, 11:10 PM
X-mod Innovator
sig ok or still too big?
01-03-2004, 11:26 PM
Topsoul to 540 out
Why don't you use a bit motor and put a propeller on it. Or if you want an even smaller motor..use a digi-Q. You can use the rechargeable batt and charge it every time you run the car or you can use a different source of power...i.e Light kit?
RCtunerzforum.tk
Your source for micro RC tuning!
Back Up My Hard Drive? How do I Put it in Reverse?
01-03-2004, 11:32 PM
X-mod Innovator
god idea i tried that but to run power to those motor i have to solder wires to it too small and tough
