Old 12-29-2003, 12:50 PM
lckyrocket lckyrocket is offline
Rocking out
If you get stuck in a crack or a rug where only one of the rear wheels is thouching the ground. If you are to lazy like me and you dont want to get up to lift it out of the crack, switch into low throttle rev it, then switch it into high throttle so it rocks out of the crack. Its been working for me, hopefully it works for you.
Old 12-29-2003, 08:12 PM
Anyone try it yet?
Old 12-29-2003, 08:19 PM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
revving a motor without load isn't good for it. also, the range on these cars is limited so walking over and getting it shouldn't be a big problem.
Bit Char-G= FRIED WITH 4.0 MOTOR
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 12-29-2003, 09:06 PM
Ok, thanks for the warning about revving. I dont rev it much though. Also when I sit down on my sofa to drive and I got comfortable, I aint getting up.
Old 12-29-2003, 11:02 PM
Daazndood Daazndood is offline
revving is bad? dam! i do it all the time. like. all the time!
Old 01-01-2004, 06:59 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
damn so i guess i shouldnt be driving on my dusty garage floor. from a dead stop my civic sits there for at least 1 second until the tires start gripping. but its awsome to show people.
NEVER UNDERESTIMATE THE POWER
Old 01-01-2004, 08:18 PM
pbmax's Avatar
pbmax pbmax is offline
Li-Ion Addict
Revving w/o heavy load on the motor is not going to hurt it. It has a load - the drivetrain. This is enough to keep it from damaging itself.
pbmax
Old 01-01-2004, 08:31 PM
neurokinetik's Avatar
My range is good enough that I have a hard time telling what direction the car is facing when it is running...
Old 01-01-2004, 10:14 PM
Ditto
My Xmod Skyline:
Stage Two Motors
Foam Tires (sometimes)
Mild/Wild bodykit (mixed)
Command Logic Lights
Awesome Graphics
6th cell in the works
Old 01-02-2004, 09:45 AM
lemans23's Avatar
GT3 Drift Master
no. trust me. that isnt' enough load. u need the load of the friction against the ground. i got a tmaxx like 4 yrs ago or something and i always kept it off the ground cause it sounded like i was street racing a motorcycle. well, after a month, it died just like my elec 4tec did doing the same thking. now that i have my rustler, i never even run it in the air unless im clearing the engine in a race.
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-02-2004, 05:57 PM
why does it get messed up? does the whole car get messed up? or just the motor?
Old 01-02-2004, 11:29 PM
O well, at least it worked
My Xmod Skyline:
Stage Two Motors
Awesome Graphics
Old 01-03-2004, 10:33 AM
lemans23's Avatar
GT3 Drift Master
the motor get's jacked. high rpm running isn't good for a motor. it puts excessive wear on the motor. like would u sit at the stoplight and rev ur engine for 10 minutes? wait. so would i. but just the same, revvin it hurts it.
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-03-2004, 11:12 AM
QPizzle QPizzle is offline
Send a message via AIM to QPizzle
foam tires.
Old 01-03-2004, 11:42 AM
What about foam tires? I hate posts that make no sense
My Xmod Skyline:
Stage Two Motors
Awesome Graphics
