Old 01-01-2004, 11:49 PM
juspifool juspifool is offline
Send a message via AIM to juspifool
Skyline Problems
My skyline works fine when you are close to it, but if it gets 10 - 15 feet away it starts cutting out, then stops. What is wrong with it?
Thanks
Old 01-02-2004, 07:29 PM
Anyone?
Old 01-02-2004, 09:22 PM
BluCivic00's Avatar
BluCivic00 BluCivic00 is offline
is your antenna connected? if so make sure its connected the right way i had mine on wrong so the metal wasnt touching the antenna and it wasnt working as good...
"Sex should be like a riced out civic; slow, obscene, and loud enough for the neighbors to hear..."
Old 01-03-2004, 08:37 AM
byebye's Avatar
byebye byebye is offline
It's an x-mod...........
Old 01-03-2004, 09:09 AM
geofroley's Avatar
R34 Skyline is God
Very good little boy, they are XMODS!
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 01-03-2004, 09:23 AM
byebye's Avatar
What's your diagnosis? Old man....
Did I hit a cheap spot in your little RS R/C heart.....
Old 01-03-2004, 09:31 AM
Bad Company's Avatar
Come on, back on topic...
Old 01-03-2004, 09:35 AM
byebye's Avatar
IRT the distance problems you could have a bad solder connection where the antenna and wire screw together. YOu can re solder or strip and resolder it. This may help. Be careful not to short the antenna lead to the motor or batt leads which would surely decrease distance. Hope this helps.
Old 01-03-2004, 09:59 AM
Thanks, I'll check it out.
Old 01-04-2004, 11:40 AM
I soldered a whole new wire in for the antenna, and it is still the same. Any more ideas?
Old 01-04-2004, 01:29 PM
byebye's Avatar
It's possible that you may have already shorted it out. You can remove any of your mods and try to take it back. Just let them know that all of a sudden the range is short and hopefully they will refund your money. Make sure you have batts in it just to show them what's wrong.
Old 01-04-2004, 01:32 PM
Patriot13 Patriot13 is offline
Check Crystal
Check that the crystal is seated properly. I had that problem becuase I bumped the crystal causing it to loose contact and studder around the race course.
Old 01-04-2004, 02:13 PM
rb26nate rb26nate is offline
Send a message via AIM to rb26nate
this happen to my friend with his skyline... we just soldered the whole connection
currently not working
Old 01-04-2004, 03:05 PM
I would take it back, but I painted it. I don't think that they would take it back like that. Is it possible to buy a new board?
Is this the part I would need?
12414207 - PCB ASSY RECEIVER $9.49
Old 01-04-2004, 03:13 PM
jaubery jaubery is offline
A friend returned his and it was painted. No hassels whatsoever.
yellow skyline -> steering problems Blindeye_03 XMODS 5 12-07-2004 10:01 PM
rsx to skyline VaTifosi XMODS Parts and Hop-Ups 1 11-27-2003 02:29 AM
Problems with R-Specs... Vyrus bitchar-gmotors Customer Support 6 02-27-2003 03:02 PM
Blitz Skyline clone body up for trade(custom lip) Superimport2nr Bit Char-G / MicroSizers 2 01-09-2003 11:26 PM
