Old 01-01-2004, 03:37 PM
LithiumXmod LithiumXmod is offline
Stage 3 of my xmod
Stage 3 of my work, pure speed! My fet's are mounted on the motor heat sink. The blue can you see is the 10,000uf power Cap. Mounted on each side is 2 CR2 lithium batteries
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
Old 01-01-2004, 04:16 PM
neurokinetik's Avatar
Be careful of that... You can't have the tabs of all four transistors attached to a metal heatsink without using some kind of insulator. Otherwise you'll short out the motor output, possibly taking the FETs out in the process.
Old 01-01-2004, 04:36 PM
10_second_supra 10_second_supra is offline
xmod destroyer
that's pretty cool it looks like a big pile of batterys and wire
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
Old 01-01-2004, 04:56 PM
superglue doesn't conduct eletricty, unless im wrong?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 01-01-2004, 05:09 PM
So what did you do? Glue to plastic casing of the transistors to the heatsink? It's hard to see in the pic.
Old 01-01-2004, 05:13 PM
I glued the fins of the heat sink to the motor heat sink, the car runs fine. If something was wrong, my batteries would have heated up really bad and give off a smell. neurokinetik, do you happen to aim?
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 01-01-2004, 05:20 PM
True, but it still seems risky to me. I would have used an ohmmeter or continuity tester to make sure that the transistors are truly isolated. The other problem is, over time, that setup is going to be exposed to vibration. Sooner or later, the transistors are going to be conducting across that heatsink. When that happens, it won't be good.
No I don't use any form of IM...
Old 01-22-2004, 05:47 PM
I Shall Return!
whats dose a power cap do?? and whats the highest cap that i can put on
Old 01-22-2004, 08:30 PM
scatmanjohn01 scatmanjohn01 is offline
whats the huge capictor for, and whre does it connect to etc?
Old 01-23-2004, 01:39 PM
godsmistake's Avatar
godsmistake godsmistake is offline
That's some crazy stuff! Where'd ya get ur fets and what type are they?
FOR SALE: Near Fully Upgraded XMOD $50!! RedRSX Miscellaneous Discussion 0 03-21-2004 09:16 PM
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 04:42 PM
xmod and mini x sawhit4 XMODS Mods and Projects 21 01-25-2004 02:03 PM
stage 1 and stage 2 endbell hoopsta1423 XMODS Mods and Projects 1 01-14-2004 01:45 AM
