12-23-2003, 06:55 PM
sharper turns
12-23-2003, 07:06 PM
AWD upgrade kit at Radioshack...
12-23-2003, 07:18 PM
("\(0.o)/") Rawr!
No not AWD, get the suspension upgrade, it had tierods upgrades too so u can have sharper turns
Xmod Parts Help
AWD gives you sharper turns.
12-23-2003, 07:43 PM
Subaru WRX STi
I dont think AWD gives you sharper turns...it just gives you better traction. I would go with the suspension upgrade....... 4.5 tierod
12-23-2003, 08:10 PM
AWD slows you down. I got the suspension upgrade and mine does 180s with my setup when brakes tapped. My set up is soft (red) springs up front and stiff (blue) in back. Soft tires in front and hard in back...Also tap the brakes before you turn, see if that satifes you. it might be the fact that you are going into the turn to hard and your cousin is simply slowing down...?.....just my 2 cents...
-Josh-
-Supra Chassis
-Stage 2 motor ( drag )
-Hard tires at rear soft up front
-stage 2 suspension ( soft up front and stiff rear )
-Wheel kit ("snow flakes")
- Tie rod
-Revell 240z model body ( custom mounted and painted blue with white hood )
-Light kit
-Custom graphics
- The most deadly soldier is the soldier without the instruction manual for his gun.-
12-23-2003, 08:58 PM
springs
in the suspension set is it the springs or the bars that make the wheels turn
12-23-2003, 09:08 PM
Try using a combination of brake and less throttle, I can do perfect turns with my RWD Supra...
12-23-2003, 10:00 PM
Subaru WRX STi
Re: springs
Well the servo makes the wheels turn...but i think you mean wich one makes it turn sharper. The springs allow more and less body roll, the tierods atcually make the wheel turn sharper...so the anwser is the tierods
12-24-2003, 09:42 AM
on the remote there is a dial that says st. range make sure its at max that may help and wont cost nothing. sorry i tried
12-31-2003, 07:26 AM
yeah that also can be the problem. But when you say you need "sharper" turns do you mean yours dosnt turn sharp at all and you turn in big circles or that you do turn sharp and just need sharper. Cause the control thing will work if thats the case
-Supra Chassis
- Tie rod
-Light kit
-Custom graphics
