Old 12-17-2003, 09:32 PM
lowam lowam is offline
my ( kind of still a mini-x) rock crawler
mostly aluminum. drive train is two old modified futaba servos. they produce the kind of tourk that i needed to pull this thing around and then some.its a 1/24 scale. sorry for the crappy camera. hope you like them.
Old 12-17-2003, 09:33 PM
here's another sorry i meant to post these in the pics
Old 12-21-2003, 10:32 PM
sawhit4 sawhit4 is offline
it looks good but bigger tires would help to complete the monster look. after i get my mini x and mess with it stock i plan to do a mod like this with u joints. but that will be awhile off cuz i dont even get the mini x untill christmas (4days )
Old 12-23-2003, 02:27 AM
thank you!
''if you want to feel funky. feel free!but please dont get that funk on me.''
Old 12-23-2003, 11:39 AM
did you make that chassis? and what kind of shocks are those? and did you just cut out the front and back diffs like helldriver did? i think thats what he did.
Old 12-23-2003, 12:02 PM
i cut the chassis out of aluminum. the shocks are off of a kyosho 1/10 on road car, i forget what it was called.an as for the diff.i just cut the minix in half and started hacking away untill i got the shape that i wanted. most of the drive train ended up being cased in aluminum so that i would have a place to hook the shocks and links to.
Old 12-23-2003, 12:23 PM
sweet did you use U joints? if you did what kind are they? it looks awesome and with some huge monster tires on it. how fast do you think it goes? it looks bad keep up the good work
Old 12-23-2003, 03:02 PM
there are no u joints. i mounted gears on two modified futaba servos and mounted the servos directly up to the diff gear. it is really slow but i wasnt going for speed . i was going for serious tork. and it has crazy amounts of tork. it will climb almost anything.
Old 12-23-2003, 11:32 PM
diets diets is offline
@lowam
Cool Crawler!
Could you please post some pic's how you mounted the Futaba servo's to the diff's.
How did you made the steering? Do you have four wheel steering as well? Pic's?
diets - has no room for the servo's
Old 12-24-2003, 05:46 PM
n 4 wheel steering but can easily be done just do the rear steering the same as the front. here are some pics. i hope you can make them out.
Old 12-24-2003, 05:49 PM
see how the mini servo sits in front and the futaba servo stands upright behind the mini servo. if you arent concerned about speed but want ungodly amounts of tork, this is the way to go. i hope these pics help. if you want me to i will get some more pics when i have some more time.
Old 12-24-2003, 07:27 PM
what did you do to the servo to make it to where it will spin without stoping?
Old 12-24-2003, 10:14 PM
rip out all of the electronics and the pot. hook your wires directly in to the motor leads. the main out put shaft/gear has a little stopper that you will have to grind off. also on the inside of the out put shaft/gear there is a little thing on the inside that you will have to remove .this is what positions the pot and tells the servo motor to stop or keep turning when it was all intact. i would take some pics but my camera is not good enough for that kind of thing.
Old 12-25-2003, 03:40 AM
SKYHIGH SKYHIGH is offline
I was just snoopin around other boards and you caught my attention. Nice work with aluminium. I do belive the your 1:24 scale r/c sits higher than my crx. That is truely sad
Old 12-25-2003, 09:23 PM
lowam i get what your saying ive taken apart a servo for a failed micro car project before. i just got my mini x and xmod today. i dont have the charger for the mini x yet but it came fully charged so i did a couple of laps around the kitchen counter with my dad driving the xmod. he won only because this little car went so fast i couldnt keep it goin straight. i went outside into my gerage and drove around to get the feel for the controls. we had a redo and i kicked his butt. i love my mini x. i got a mini cooper model to make into a bodie for it and it should be done by tomorrow. ill post some pics. later
spencer
Rock Crawler p4tch For Sale/Trade 6 07-28-2006 02:37 PM
how do u make an xmod h2 a rock crawler crazyone XMODS 2 12-29-2005 02:59 PM
1/24 Rock Crawler bluemonster TTTT 4 01-08-2005 12:27 AM
Check Out my custom MINI Rock crawler Maxxcrazy Other Tiny RCs 6 09-22-2003 06:59 PM
just about to order mini z or mini x but have a question tarnjit Mini-X 0 12-22-2002 10:01 AM
