Old 12-20-2003, 10:50 PM
Venom5.0 Venom5.0 is offline
Faster in Reverse than forward? SBP
How's it goin? New to the forum, but long time RC user. Anyway, I recently performed the spinbrush mod using the stage 2 armature and endbell with the sb can. It seems to have a bit more top end in reverse than it does going forward (when held off the ground). Has anybody else experienced this with their sbp?
As well, this motor seems to become relatively hot compared to the standard stage 2 motors. Is this because of the hybrid combo I am using? I guess my concern is, can the ESC handle this setup (Stage 2 arm + endbell w/sb can) with out it burning out?
On a side note, I found an old mabuchi motor from a record breaker (old non rc car from the late 80's? - I'm 28btw and lovin these things) that I plan on integrating into the X. Hopefully results will be good with the 10 tooth pinion. I'll be posting results if I get a chance. Later y'all.
Jamie
Old 12-20-2003, 11:51 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
xmods like to run motors backwards compared to others like mini-z. the timing must have been set for the other direction. search for the thread advancing timing or something to that effect by neurokinetik. he has a tutorial showing you how to adjust the timing. his pictures shows advanced timing in the proper direction
*Edit*
aahh forget it, here's the link lol http://www.tinyrc.com/forums/showthr...threadid=15954 good luck
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-21-2003, 12:09 AM
neurokinetik's Avatar
He said it is a stage 2 armature. All the Radio Shack motors have neutral timing by default. It's the motors for the Mini-Z and Micro RS$ that tend to have the timing retarded for XMods.
ESC shouldn't have any problem with that combo. It really doesn't draw much more current than the stock stage 2.
Old 12-21-2003, 07:54 AM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
sorry to be a bother but wat is ESC
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Old 12-21-2003, 03:14 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Micro RS$. Those things (Like all HPI cars) are quite a rip. I think I put less money into my nitro touring car.
The heat is due to the stage 2 armature. It runs hot, unlike the spinbrush one, and the better magnets may make it hotter (I don't know too much motor magnet theory). I can't figure the reverse problem. Since you're using the stage 2 armature and endbell, it should be the exact same, just with stronger magnets. Unless the magnets' poles are in the wrong place...
Old 12-21-2003, 05:09 PM
Bad Company's Avatar
Electronic Speed Controller
Old 12-23-2003, 12:06 AM
Thanks for the replys guys. Glad to know that the ESC should be safe with that combo. Still puzzled on why I'm getting more rpm's in reverse, though. The motor was assembled correctly and in theory, like Nathan mentioned, it should be the same in either direction. Maybe I'll pull it apart again and see if I can do something with the magnets.
Alternately, the other motor I found worked out pretty good. I'm currently running the 11 tooth on it with decent results. Pretty cool having a true mabuchi 130 in there, although I do have to say it is just a tad bit faster than the stage 2. Alright, thanks again guys!
Jamie
Old 12-23-2003, 10:04 AM
Honda 4 life
thanx bc i was thinking the escape key on the key board
Old 12-23-2003, 04:04 PM
Dramier Dramier is offline
Send a message via AIM to Dramier
I've noticed on all our Xmods, with stock and swapped motors, they seem to have about 20% more torque in reverse than in forward. My guess is that this is normal, and is used to provide "brakes" for the car.
Just my guess.
Old 12-24-2003, 03:30 PM
Honda 4 life
yay i got the xmod but im lazy and cant open the box
Old 12-24-2003, 03:33 PM
Honda 4 life
Edit
hey dramier wat county of GA do u live in? i live in GA i just put Asia to represent my AZN pride
Old 12-24-2003, 05:48 PM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
u not even a tiny rc pro.. u dont even no wat is esc
Old 12-25-2003, 06:40 AM
Honda 4 life
well it wasnt me who put the name thing on it like changed to that when i got around 30 posts
Anyone killed Forward but not reverse? Jazz32 XMODS 2 05-23-2006 08:20 PM
Very slow forward -> Fast reverse? M@rk Bit Char-G / MicroSizers 1 12-27-2002 03:29 PM
Why is my bit faster in reverse? st5150 Bit Char-G / MicroSizers 4 09-25-2002 03:26 AM
Bit runs faster in reverse....?! Crisp_Rapper Bit Char-G Parts and Hop-Ups 3 08-29-2002 12:10 PM
