Old 12-20-2003, 08:10 AM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
Look what I found!
I think I found why they are so fricken slow! There is a small blue capacitor behind the battery. It was hiding under a hunk of plastic. I'm sure if we removed it the cars would perform better.
Old 12-20-2003, 01:26 PM
spoop
its because it is so heavy
Old 12-20-2003, 01:42 PM
payaso payaso is offline
BIT PIMP
Re: Look what I found!
Why would you say that? Just yank it out, and tell us your results.
silla
Old 12-20-2003, 02:54 PM
Racer9's Avatar
Tiny RC Pro
1st of all I can't charge my car for some reason so I will wait until I get another one before I rip into this one too much (I am sure it is the fricken controller).
Old 12-20-2003, 08:00 PM
charliebrown's Avatar
.....Maybe it's cuz your car isn't even turned on?
Also, check the battery inside, you have to match the positive and negative ends correctly. The ends are different spots than the original ZipZaps Micro RC.
Chuckster...
Old 12-21-2003, 05:11 PM
Racer9's Avatar
Tiny RC Pro
everything is connected and it worked just before so it is some electronics problem. Yes the car and controller are on!
found some new MiniZ's ksavage68 Mini-Z - Mini-ZRacer.com 1 10-04-2003 01:32 PM
Found Steering Problem You Should All Look At This!!! Jr08bll Bit Char-G / MicroSizers 28 04-12-2003 12:32 AM
looks like I found another hobby Purple Penguin Combat Digi Q 4 12-11-2002 04:26 PM
More cheap bodies (and more) found at Dollar Tree brianpipa ZipZaps 14 11-25-2002 09:30 PM
