Old 12-19-2003, 08:51 AM
census007's Avatar
census007 census007 is offline
Drift withit
how do you widthin a body
i found the nascar body in the dollars store it is perfect but it is not wide enough it fit help please !!!!!!!!!!!!!!!!!!
Old 12-20-2003, 01:09 AM
itsme
Is that even possible. You'd have to recreate a whole middle part from scratch for it.
Old 12-20-2003, 06:06 PM
I Shall Return!
if you good with sanding, and cutting (and if you want to.. you could cut the body down the center ( long ways) and add a strip of plastic to make it fit, then use a sodering iron to attach everything together, and sand her smooth, hope i could help
Old 12-20-2003, 10:04 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
You could definatley do it, you just need to cut the body down the center and fill it in with plastic or putty. you should put too much on, and then just sand it until it's smooth. I would also pu tin some suppors going sideways to make it stronger.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
Old 12-20-2003, 10:23 PM
I Shall Return!
yea i agree, good hunting
Old 12-20-2003, 10:50 PM
I Shall Return!
Old 12-21-2003, 01:03 AM
itsme
Cutting it from the middle and adding some plastic wont make it look good. You'd have to bring the window indented like the car. Make the front bumper look the same, and the back bumper along with make the curves the same...
Old 12-21-2003, 07:46 AM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
thats kind of why you sand
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Old 12-21-2003, 01:14 PM
itsme
Putting one long piece of plastic and sanding that won't work. Think of getting the sanding paper in the bumper cracks?? m hmm -_-
BC's Xmod Masking/Painting Tutorial Bad Company XMODS Mods and Projects 30 07-15-2007 11:13 PM
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 12:19 AM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 01:48 PM
WTT: wanted: nissan gloria gunmetal body blght For Sale/Trade 5 03-08-2003 10:44 PM
Body post Modification DAMZer ABC DTM Parts and Hop-Ups 2 08-25-2002 10:07 AM
