Old 12-18-2003, 05:08 PM
census007's Avatar
census007 census007 is offline
Drift withit
can you fit 6 cell in teh supra and a logic light kit
can you fit 6 cell in teh supra and a logic light kit. i have benn trying so hard to fit if but i make it work help
please post pic too
Old 12-18-2003, 05:32 PM
theMonster's Avatar
Got Brains?
I wouldn't do it
There's a lot of people who've toasted their cars doing this....There's a thread on here somewhere dedicated to that particular problem.
This is your brain.....
Old 12-18-2003, 05:45 PM
census007's Avatar
Drift withit
search the forums but could not find anything can you give me a link or some help fittng it in
Old 12-18-2003, 10:21 PM
batesjm's Avatar
batesjm batesjm is offline
My Alter Ego Is Retarded
You can fit 6 cells and the light pcb under the body of the supra. You however can not fit a 2 AAA cell holder under the body. You will need to hard wire a 2 cell pack under the body. You will also need to remove the pcb from the top of the car and remount it. Basically its a real bitch to do and you need to devise a way to charge the cells with out removing them from the car. Sorry I dont Have any Pics. But unless you have a good charger and the means to develop an in car charging system I would not recomend it.
I like Pie
Old 12-18-2003, 11:06 PM
census007's Avatar
Drift withit
is that what you did
Old 12-18-2003, 11:38 PM
batesjm's Avatar
Yeah, The batteries are never removed from my car, I bought a 3/32 phone jack and mounted it to the car, and use the corresponding plug attached to my charger. it works very well but it was a pain in the ass to do.
I like Pie
Old 12-18-2003, 11:39 PM
census007's Avatar
Drift withit
is there any way yo can post a tutorial
Old 12-18-2003, 11:46 PM
batesjm's Avatar
its pretty simple just solder the connections to the jack to where the + and - leads come off of the stock battery holders. When wiring tbe plug use a multi meter to be sure the + imput from the charger is putting juice to the + battery wire and you are good to go. Its simple in theory but a hard mod to do because of the tight space in the supra body, and its also hard to mount the jack. I mounted it to the body as a gas filler.
I like Pie
Old 12-19-2003, 06:57 AM
I Shall Return!
im not sure how the chip looks but couldnt you mount the batteries under the chip, or you can make your own custum holder under the actual body by glueing peices of sheat metals/ spring/aluminum foil as contact points to the plastic and then completeing you curcuit, or (what im aiming towards) custumising the batt case, but their are other ways, if you search you'll find people who have gotten the holder under the body by messing with the mounts, i hope this shines some light on the situation
Old 12-19-2003, 04:31 PM
Bad Company's Avatar
You can mount a 2 "AAA" battery holder under the Supra and Skyline bodies with a little dremel work to the inside, that is what I did.
Old 12-19-2003, 04:37 PM
I Shall Return!
hey b.c. i saw that at one of your posts but it dosent make sence 2 me (mainly because i havent seen an x-mod in person.. i can only asume its 3X bigger than a zip cuase of the scale)... did you raise the body mount, or carve out the body??
FS 5 cell RS4 powered AWD Supra LOTS OF PARTS 4 Door LT1 For Sale/Trade 3 09-26-2007 10:46 AM
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 08:43 PM
Problems making 6-cell fit in Supra AgnstAllOdds XMODS Mods and Projects 14 02-23-2004 10:11 AM
5th cell and light kit. RGM1524 XMODS Mods and Projects 3 01-06-2004 03:23 PM
how to light up your xmods interior without buying a kit rpm XMODS Mods and Projects 2 12-27-2003 09:44 PM
