Old 12-14-2003, 07:58 AM
geofroley's Avatar
R34 Skyline is God
If the Crest Spinbrush motor was an XMOD motor what stage do you guys think it would be in??
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 12-14-2003, 10:14 AM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
the spinbrush motor would be a fractional stage...ya know, less then stage 1. Probs like 1/3 stage...pushing like 14,000rpm
Old 12-14-2003, 11:24 AM
geofroley's Avatar
R34 Skyline is God
Dude stop denying the fact that it's a good motor. Your just jealous cause these guys got a great motor for $3.99 and you paid $40 for your NML so jsut shut up dude.
Old 12-14-2003, 12:34 PM
RedRSX's Avatar
Subaru WRX STi
ok sorry...dude...ill stop dude, no need to get pissed dude
Old 12-14-2003, 06:53 PM
Lucid Dreams
dude i think ur like jelous....... dude
Old 12-14-2003, 06:54 PM
Bad Company's Avatar
Enough, carry on with the thread topic please.
Old 12-14-2003, 09:05 PM
RedRSX's Avatar
Subaru WRX STi
jealous...LOL...good one
Old 12-14-2003, 10:33 PM
census007's Avatar
census007 census007 is offline
Drift withit
so is their a tutorial for the spin brush mod or not
Old 12-14-2003, 10:42 PM
RedRSX's Avatar
Subaru WRX STi
I haven't seen one yet...but if someone has one...i would actually like to see it, so that I could make a solid opinion about it
Old 12-17-2003, 02:48 PM
SimonTr SimonTr is offline
Send a message via AIM to SimonTr
It is rather easy to open the SBP brush.. all you have to do is take a hammer and break open the bottom part.
I now only use the SBP motor in all 4 of my xmods. They are cheap buy very fast. Well not very fast, but the torque is a killer.... I use the 10 and 9 gear tooth on mine.
I did a test with the zip zap track tester using stock stage 2 and SBP motor.
(fpm= feet per min) (mpm= miles per min)
Stage 2 red = fpm=721, mpm=532
Stage 2 yellow = fpm 683, mpm=494
SBP red gear = fpm=800, mpm=587
SBP yellow gear = fpm=834, mpm=603
this is an avg. of 4 runs each.
10 foot drag strip with the zip zap speed checker set at the end.
I've also swap parts around and found that it really increase the speed and torque of the motor. I'm at school right now, and don't have the records with me.
but if your using the SBP motor, you will need to take the brushing off from one of the stock and put it into the SBP... other wise it will burn the brushing only after a few run.....
If ppl say that the SBP motor isn't fast. they are right, but the motor has crazy torque... from stand still to top speed is really quick, all you have to do is change the gear to a higher one to even out the torque with speed.
i've raced 6 ppl so far and haven't lost once, maybe a few times to my little bro who also has the same motor. Plus the motor does not heat up as fast as the stock ones do.
Old 12-17-2003, 07:03 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
geofroley where in Harleysville do you live? I live about 20-35 minutes away.
Old 12-18-2003, 08:41 AM
aperson's Avatar
aperson aperson is offline
all i have to do is take the capacitors and plug w/ wires off and put it in right?
Old 12-18-2003, 09:20 AM
neurokinetik's Avatar
You are correct sir. Leave everything soldered to the brushes, and just desolder the caps from the motor can itself. Swap the whole thing over to the spin brush can.
Old 12-18-2003, 06:23 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
I've heard using a stage 2 armature makes for event better performance. Apperently the magnets are the only thing the Spin Brush motor has that is special, other than that it is pretty normal. And $4 .
Ghetto rules. God helps those who help themselves. If no one ever ghetto rigged anything, we would not have cars or radios .
Old 12-19-2003, 01:53 PM
geofroley's Avatar
R34 Skyline is God
In the outskirts of Harleysville. About 10 minutes away from Souderton.
Spinbrush magnets (courtesy of xmod forums) cdog4w Mini-X Parts and Hop-Ups 2 02-28-2004 10:34 AM
Spinbrush, Stock FET's & RCP track rlc77 XMODS Parts and Hop-Ups 3 01-29-2004 01:38 AM
Spinbrush Motors Work! MicroSpeed XMODS Mods and Projects 29 12-13-2003 11:46 AM
SpinBrush Suggestion sherifx XMODS Mods and Projects 9 12-07-2003 01:34 AM
