Old 10-11-2002, 10:43 AM
e_lm_70 e_lm_70 is offline
Send a message via Yahoo to e_lm_70
Bit - Digi - SmartLand
Here is my colection.
iRacer are comming.
The Pic is from my 7650 so not too perfect !
Old 10-11-2002, 10:45 AM
Here is a "close" look of:
Digi-Q
Smartland
Bit-Charg
Bullet (modified) putted with force a big 1/3 AA NiCd 120mAh
Old 10-11-2002, 10:47 AM
My B Track !
125x80 cm
Record 3.28 sec with Bit-Booster 3.0
Old 10-11-2002, 11:55 AM
323iT's Avatar
323iT 323iT is offline
did you make the side of the track out of these bendable rulers for sketching?
Old 10-11-2002, 01:11 PM
latency latency is offline
Is that a lap timer/counter?
I have been considering making one for my ZZ track out of the laser point and photo cells, using different height flags on the cars antennas to trip the laser beams. I have seen this setup for the Mini-Z cars.
Curious what your timer/counter does and how it works. Work only for one car?
Must explain!!
Pic of my track:
skinny sig
Old 10-11-2002, 09:51 PM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
Hey, nice tracks both of you!
Could you describe them in detail?
Size, materials, construction, etc...
Thanks!
Old 10-14-2002, 02:14 AM
Thanks!
Hi,
The "latency" track look more cool then mine,but:
- It is my first track
- I have invested little money and just 3 hours on building (manly because I changed my mind about the track shape 3 times !)
- It is very light (no more then 100g)
How it is done:
The black base is what it is normaly used for be putted between the raw flor and the carpet, I found it on "House Building Shop" (BauMax) : 3$ for 125x80x0.5 cm. The black base is a sort of "expanded rubber", 0.5 cm thick, very very weak, but for light cars like the bit, it is not a problem.
The blue lines come out of a "multy purpose" carpet, it is made out of stronger "expanded rubber", that I have easly cutted with a knife. This carpet 100x60x3 cm was little bit more expensive (15$) but can provide me enough lines for 4 or more tracks !
The lines are not glued on the base, since in case I change my mind I can redesign it !
The lines are just connected with small nails with a wide flat cup. For be sure to don't lose nails around the flat, I just use a easy removable scotch tape on the rear side, this fix better the nails and also help on not scratch the flor.
Cost for the small track : 8$ plus 2 hours !
I'm going to build up a bigger track, using to bases (160x125cm). Plus drugster track (250x40cm).
e_lm_70
My record is now lowered to 2.8sec with Bit Booster, the only way to drive a Digi-Q on the track is to set the maximum speed at 2/8 using the Special controller.
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Want to trade a ZipZap for something, Maybe Digi Q/Or Bit Char-G spaz13 For Sale/Trade 5 01-20-2003 08:41 AM
Digi qvs Bit Charge G pakiplaya Bit Char-G / MicroSizers 3 12-18-2002 08:08 AM
Digi Q control conversion for BIT CharG slotsurfer Bit Char-G / MicroSizers 11 05-23-2002 09:55 PM
