12-13-2003, 06:18 PM
Originally posted by Plays_with_Toys
If you're looking to make a drag car there are some other tires you should get. They are just as grippy, but have a street look to them. They come in a lego kit that is a car that you pull back and it winds the motor. Here's a pic of them on someones overland:
They fit right over the xmod wheels but are just a tad wide. If you have them on the rear, than rubbing shouldn't be a problem... Unless your doing a FWD drag car, which would look so cool! Just remember that your acceleration will suffer big time, because of the taller tires, unless you have motor/battery mods to compensate.
Oh, I have the motor, believe me.
I'd probably use the ZR1 body with these tires, make it RWD with some skinnies up front. Actually, I remember seeing some drag wheels and tires at my LHS. In fact, I'll be right back...
12-13-2003, 06:22 PM
R34 Skyline is God
Whats your motor again nuero?
My Bit: Phast motor  (Orange)
Soon to come:  (Undecided) Custom Rims
12-13-2003, 06:31 PM
Team Orion stock motor for the Micro RS4 (180 motor), but reduced by 10 turns. It's turning more RPMs than all but one of my stage 2s and has enough torque to spin all four tires even with the top speed gears in it. Did I mention this motor was only $13?
If this one isn't enough, I have an actual modified 180 motor on order as well.
12-14-2003, 12:02 AM
mini-eX-Driver
if you are talkin about an hpi micro mod, you will love it. it is the best low cost motor i have tried so far. i cant run my minix with it rwd or it will never get off the line.  for a 45t motor it is pretty mean. i want to see what it can do with advanced timing or with less winds
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
12-14-2003, 12:45 AM
What's this 180 motor mod trick??? Can the stock ESC handle it? What kind of modding needs to be done inside the car to fit it? If the spinbrush doesn't give me enough torque, than this might be my avenue.
AWD Xmod Crawler in the works _>
Landcruiser Z-body, AWD w/ Locked Differentials, Spinbrush motor, 30x14 Lego MT/R's
12-18-2003, 05:28 PM
I KNOW NOTHING!!!
so any updates on this?
12-18-2003, 05:33 PM
Nothings changed.
I ran out of batteries, still waiting to do the SB motor mod. I have been working a ton more hours (work at a mall, and with the holidays). I plan to work on it again next week when I go on school break.
There are some updates on my 2.2 Krawler over at RCMT if you want to see those, though I haven't milled anything yet, just designed my beadlock wheels.
12-21-2003, 12:36 PM
I KNOW NOTHING!!!
Your 2.2 krawler plans are looking good.
01-02-2004, 04:54 AM
Xmodder
Ive been readin the forum but what is RCMT?
01-02-2004, 05:18 AM
I KNOW NOTHING!!!
RCMT = radio controlled monster trucks.
It is an excellent site for RC trucks.
It is an EZboard site and can be found easily by doing a web search.
01-02-2004, 02:58 PM
Tiny RC Guru
play with toys no no dude ! you got the wrong tires on that thing you need to go back to legos and get these big tires that say 43.2x28 S i dont know if you can see the size on the box and i dont know what kit they came in but ill try to find a link oh yeah is that overland pic. an X-mod if it is howd you get it so high?heres the link http://shop.lego.com/product.asp?p=8...2D9B55E4D00267 oh and uh you might need find or modify some rims!
01-02-2004, 09:47 PM
Xmodder
that site did not work for me
*Nissan 350z*[COLOR=royal blue]
-Stage 2 red SB hybrid motor (soon to be neo mags, BB can and BB endbell)
-IC-3 800 mAH bats - 4 cell
-AWD
-Blue springs up front, silver in back
-Aluminum locknuts at all four corners
-Locked rear diff for drift action![/color]
01-02-2004, 11:07 PM
Tiny RC Guru
hmmmmmm?,well go to shop.lego.com then go to sports and cars then to cars and bikes then cars then look for nitro terminator
04-12-2004, 09:06 PM
Tiny RC Guru
you there plays with toys? hows it comin?
04-14-2004, 12:17 PM
I'm not a pyro, really.
IDK if you figured it out yet, but you need to take the 4 screws out that hold the rear end assembly on the main chassis and then slide the battery holders back and lift the back of the holder a bit and they should slide right off. if you take out the electronics make sure before you put the holders back on to leave the 2 bottom screws (on both sides of power switch) loose. the left holder is a pain to get on if you dont.
the 2 bottom screws you took out were to hold the electronics to the chassis.
NEVER UNDERESTIMATE THE POWER
