Old 12-13-2003, 10:11 AM
SpeedDemon SpeedDemon is offline
Steering Stuck
On Xmods the steering is always gettig stuck to one side. Its very annoying. Does anyone know whats wrong? How can i fix this?
MicroSizer: Perfection 4.2 Pro
2nd Microsizer:
Old 12-13-2003, 10:18 AM
jaubery jaubery is offline
What do you mean by stuck? Does it pull to the left or right when your going straight or does it just go in circles?
Old 12-13-2003, 10:44 AM
I'll turn to the right and the steering will get stuck to the right.Until i move it alot.
2nd Microsizer:
Old 12-13-2003, 11:28 AM
Could be a problem with your steering servo. Take the top cover off the front end and see if there is lint or debris blocking the servo arm or the tierod.
Old 12-13-2003, 08:32 PM
think think is offline
if thats not the problem have any other ideas??
Old 12-13-2003, 09:05 PM
The steering servo is not returning to center so... I guess you could tear apart the servo and so what's doing in there. Or using the 90 day warranty might be a good alternative.
Old 12-19-2003, 10:52 AM
johnfish johnfish is offline
My original xmod had this problem. If you are handy with a small tip soldering iron you can probably fix it but if not I would return it to RS. The problem on mine was a poor solder connection from the servo to the rx board on the bottom of the car. It required total disassembly of the car.
John
Old 12-19-2003, 11:57 AM
neurokinetik's Avatar
I have a similar problem with one of my cars. The steering servo seems to be binding up at one particular place. I have the servo apart and can't see anything wrong with it, however. It is definitely something in the gears, as you can feel it bind up if you move the servo horn by hand.
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 03:42 PM
I'm coming back just this once to help with the steering.... charliebrown ZipZaps SE 35 02-26-2004 10:11 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 01:16 PM
Steering Help ZipRC ZipZaps SE 1 09-21-2003 10:57 AM
Steering issue cdog4w Bit Char-G / MicroSizers 21 12-30-2002 11:20 AM
