12-10-2003, 08:35 PM
AA vs AAA
hello, im pretty new here but i was wondering how much of a differance it would make to change from AAA to AA batteries
thoughts and suggestions would be greatly apperciated
12-11-2003, 01:57 PM
MY ENZO!!!!!!
not much most likely because they supply the same voltage just different sizes and capacities
12-11-2003, 02:34 PM
would it make much of a differance if you ran 4 AAA and 1 AA batteries?
skyline
stage 2 motor upgrade(yellow)
IC-3's
12-11-2003, 03:22 PM
RC Tinkerer
Maybe this will help make sense of it all....
NiMh AAA = 1.2 Volt - 600 MA
NiMh AA = 1.2 Volt - 2100 MA
4 x AAA = 4.8 Volt Total
4 x AA = 4.8 Volt Total
The above battery stats are based on NiMh batteries that I have in front of me, and are not the same as NiCad, or even Alkaline Batteries.
Advntages of AA over AAA
You are looking at 3.5 times longer run time over AAA.
The Advantages of AAA over AA
AAA Batteries weigh less than AA Batteries.
AAA Batteries are smaller than AA Batteries.
I am not sure if 4 AA batteries will fit, however it is something to look into. However given the small size of the cars, I doubt that you will be able to fit 4 AA batteries and still be able to put the body on it.
I hope that this helps.
12-11-2003, 07:15 PM
mini-eX-Driver
dont forget, aaa and aa batteries have different discharge rates. the aa battery will put out the same volt as the aaa but it put out a higher amp than the aaa will. that eguals more power.
i have ran my rs4 micro on aaa's and aa's
the aaa will stutter gettin up to speed but the aa will get to speed with no prob. the same is true with my minix. i had to add a punch cap to prevent the aaa from hurtin my launch
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
12-11-2003, 07:54 PM
so it would be okay if i had 4 AAA's and 1 AA as my 5th cell or would i be better off trying to cram 4 or 5 AA's in my x mod?
skyline
IC-3's
12-11-2003, 08:17 PM
mini-eX-Driver
if you want to add a cell, just add an aaa, adding 1 aa wont do much with your setup because you wont be using all aa. if you use all aa, then your care will be heavy. the reason i was havin a problem is because i was using an esc made for aa cells or larger in both cases.
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
12-11-2003, 08:46 PM
RC Tinkerer
It will not give you an advantage over an extra AAA. The only difference having an extra AA would be extra weight.
12-11-2003, 09:16 PM
thanks for your help
skyline
IC-3's
12-13-2003, 06:10 PM
the "too many tires" guy
or you could just replace those 4 AAAs with 2 AAs and have longer runtimes/ higher current output with minimal weight gain.
Given it might be hard to fit 2 AAs in the chassis without some work though.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
12-13-2003, 07:10 PM
mini-eX-Driver
2aa's is only 3volts. that thing will crawl! that is 3volts if they are alk's if they are nimh's then thats only 2.4volts at best
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
12-13-2003, 10:41 PM
RC Tinkerer
AAA - 1.5 Volt
AA - 1.5 Volt
AAA * 4 = 6 Volts
AA * 2 = 3 Volts
You would not get longer run tumes with only 2 AA's, you would get less than 1/2 the speed. (If the car moves at all)
I think your math is a little off.
12-13-2003, 11:53 PM
lol
but see im buying this energizer thing that charges in 30minutes and it comes w/ 4 AA's free and ill buy like 8AAA rechargeables. thats y i wanted 2 no if haveing an AA as a 5th cell would b ok
thanks fer all the input btw
skyline
IC-3's
12-14-2003, 12:07 AM
RC Tinkerer
It will work Both AA and AAA rechargame batteries are 1.2 volts. So if you have 4 of either size you end up with 4.8 volts. So if you add another 1.2 volt battery of either size you will end up with 6 volts. And you can mix 1 AA with 4 AAA, just keep in mind you can only charge AA with AA, and AAA with AAA. Do NOT mix them when charging. However because they are rechargable batteries, you will want to keep an eye on the batteries incase they start to get warm.
12-15-2003, 03:03 AM
Doh!
This is case in point why I should stop posting so late at night :P
Body Kit
Stage 2 drag motor
Hard tread Tires
NiMH batteries
Yellow Skyline RWD
Stage 2 Drag motor
4.5 Tie Rod
Soft Tread Tires
