Old 12-08-2003, 10:27 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
Well that's not exactly a good thing......
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
1.5 steering rod.
Soon to come: Body kit
Old 12-08-2003, 10:30 PM
shaolin_racer shaolin_racer is offline
Originally posted by miniDRIFTER
what exactly is the spring rate? can someone please explain what spring rate means?
Spring rate is the amount of force required to compress a spring a certain amount. ie: 300lbs springs will require 300lbs to compress them one inch.
Old 12-09-2003, 11:12 AM
Patriot13 Patriot13 is offline
Originally posted by RSXRacer001
i heard that with the awd it makes the turning radius bigger. is that true? and also does it make you less likely to drift b/c i want to drift
I think you could stiffen the rear suspension, or put harder tires on the rear if you want the car to break rear traction first and drift.
Old 12-09-2003, 02:59 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
more torque is better for drifting and i like to drift.
and thanks for the info about the rear springs.
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 07:43 PM
question about the suspension and steering upgrade kit LightFetish XMODS 1 01-30-2006 11:48 AM
I got the new upgrade kit. Zephyranthes ZipZaps 6 10-01-2005 08:56 PM
XH XMOD Wire Upgrade Kit NOW TAKING ORDERS XAnubis XMODS Parts and Hop-Ups 8 12-12-2003 02:09 AM
German Import Upgrade kit airline2 ZipZaps 11 12-24-2002 10:06 AM
