Old 12-03-2003, 03:39 PM
geofroley's Avatar
R34 Skyline is God
Underglow idea.
My idea was take some Christmas lights and hook them up to a battery pack and use a switch to turn it of and on. Post what I should do here.
My Bit: Phast motor (Orange)
Old 12-03-2003, 05:04 PM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
yeah i thought of it a long time ago when xmods was new and posted it but i dont have an xmod to do it on so tell me how it go
Old 12-03-2003, 06:23 PM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
yo sup when yall done with the mod could you post pics and how-to-dos
it would realy help since i dont want to screw up my car
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Old 12-04-2003, 07:23 PM
geofroley's Avatar
R34 Skyline is God
I'm gonna get the stuff from Radio Shack, like the switch and the battery. I need to a bit more studying though first.
Old 12-06-2003, 06:18 AM
Honda 4 life
all right take ur time I'm in no hurry
Old 12-06-2003, 02:45 PM
shibby's Avatar
shibby shibby is offline
hey mike from one one18th makes under glow its for a micro rs4
maybe they would work on an xmod with some mods
http://shop.one18th.com/product_info...products_id=65
arguing on the internet is like the special olympics even if you win your still retarded
Old 12-06-2003, 03:52 PM
funkytones funkytones is offline
well... since those are for 1/18... and xmods are 1/28... thats a big difference... those wont fit unless you fab a trailer and pull it behind yo skyline or somthing to carry all the stuff... and the inverter... you more surely wont get that to fit under the body... soo... those wont work...
Old 12-06-2003, 03:54 PM
shibby's Avatar
thats why I said with mods
i know the difference between scales
plus anything can be done if you puy your mind to it
yeesh
Old 12-07-2003, 09:02 AM
Omega_Maxx
Um...I posted on how to setup LED lights afew weeks ago....do a search under Underbody lights I think or something close to that
Old 12-07-2003, 11:27 AM
tavisjohn's Avatar
RC Tinkerer
It is not that hard. You just need to figure out how mutch voltage each light will require.
For example:
If you have a 100 bulb string of lights then each bulb will need 1.2 volts.
120 Volts / 100 bulbs = 1.2 volts per bulb
And if you want to use a 9 volt battery to power your lights then you will need 8 bulbs
9 volts battery / 1.2 volts per bulb = 7.5 bulbs (8 bulbs to be used)
(Round up to the nearest whole bulb, that way you do not have to worry about the bulbs overheating.)
So if you want to use a 9 volt to power your lights you will need a 9 volt clip to connect the 8 bulbs to the battery.
I hope that this helps!
Old 12-07-2003, 07:40 PM
Plays_with_Toys Plays_with_Toys is offline
You guys are thinking too hard... Here's how my friend at wavejake RC (www.wavejake.com) did his, but never released them.
Take two LEDs of the same color. Take a clear straw. Cut the straw to length. Insert leds into ends of straw. Hook up battery. Voila. If you are not getting enough light, insert tin foil that is half the circumference of the straw to get more light projection.
Simple, ain't it If someone does it, be sure to get the pics up.
Old 12-07-2003, 09:15 PM
tavisjohn's Avatar
RC Tinkerer
A pair of high intensenty blue LED's and some of the plastic tubing used in fish tanks would work. Oh and to direct the light down, you can use some foil tape.
Old 12-08-2003, 06:40 AM
lckyrocket lckyrocket is offline
Go to RCNEON
This company also makes full size car kits so its good
Old 12-08-2003, 02:36 PM
geofroley's Avatar
R34 Skyline is God
For example:
Thanks man it does. I thought about using a 9v battery but I'm concerned about the weight. By the way I'm only using for bulbs.
Old 12-08-2003, 04:32 PM
tavisjohn's Avatar
RC Tinkerer
Then the total voltage needed to light up is 4.8 volts. But the power available in the car is 6 volts. So if you go to 5 bulbs you would have an even 6 volts. If the bulbs run too hot go to 6, they will be dimmer, but they will not be running as hot.
easiest and best underglow ever bengali548 XMODS Parts and Hop-Ups 2 08-05-2006 12:08 AM
New idea for neon underglow J-Tuner XMODS 4 12-18-2004 10:12 PM
idea for battle feild! Comrade_Boris Combat Digi Q 10 11-02-2003 03:46 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 05:30 AM
