Old 12-07-2003, 12:03 AM
JebusKrist JebusKrist is offline
xmods steering noise question
what are the normal sounds for an xmod when turning the front wheels a grinding sort of sound? mine works fine as far as i know but i've never heard an rc car make this type of noise
Old 12-07-2003, 01:40 AM
miniDRIFTER's Avatar
miniDRIFTER miniDRIFTER is offline
modSquad Member.
Send a message via AIM to miniDRIFTER
Yes, if it is a loud beeping sound. It is your car, it is perfectly normal, its the servo.
White '97 Toyota Supra
Mild front, wild sides, stock back
Stage II motors
Hard suspension
Black painted Enkei wheels
Command Logic lights (Courtesy of http://www.xmodrc.com)
In the process: XMOD™ Dynamometer (DYNO)
Old 12-07-2003, 03:15 AM
no its not a beeping at all more of a grinding/ticking sound but stops when the wheels are turn all the way left or right and they dont shudder so i guess its normal? it just seems a bit loud
Old 12-07-2003, 10:01 AM
viperkilla's Avatar
I guess there is no harm done. As long as it runs how it should, then it is alright.
Old 12-07-2003, 11:32 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
some dirt may have gotten in
NEVER UNDERESTIMATE THE POWER
Old 12-07-2003, 02:09 PM
Deep Blue Deep Blue is offline
Jebus, that sound is normal for an Xmod. The Xmod's steering servo isn't truely proportional. Most (actually, nearly all) hobby grade RC cars use a servo with say 45 degrees of travel. Those 45 degrees will be divided an infinite number of times. On an Xmod, that 45 degrees is divided 16 times. Every time you hit one of these 16 positions, you hear it click, so it sounds like it's grinding, but its not.
dB
Old 12-07-2003, 03:56 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
well it's not infinite although it feels that way, it's either 512 (typical) or 1024. our xmods won't really turn the wheels 45 degrees, it's a little less than that, haven't measured it but just by eyeballing it, it's not 45 degrees
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-07-2003, 04:31 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
yea. its not quite 45 but that sound sounds kindof normal
Old 12-08-2003, 01:19 AM
thanks alot guys im just not really familiar with "proportional" r/c cars i've only messed with zip zaps and microsizers and the occasional large r/c truck/car
Old 12-08-2003, 08:10 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
HEY!
THE SE ZIPS HAVE THE SAME SOUND! exept the zip steering
servo is just a zip motor and a gear that is connected to the wheels possibly... R.S is incorperating the same technology in
their cars im not sure how a normal steering servo works but
i think its either a magnet or a motor that is DIRECTLY linked
to the wheels...
mini z:ferrari f-40
xmod:body undecided
Old 12-27-2003, 01:35 PM
newbitowner's Avatar
I hit a wall really hard w/o the body.
Not it doesn't turn well when in motion.
Help! If it's a simple easy fix, I can do it.
I just got it today, so I on't hesitate to return it.
Old 12-27-2003, 01:45 PM
Bad Company's Avatar
Your best bet might be to just go ahead and return it to be safe. You probably stripped the servo gears. Does it turn at all when you hold it in the air? Be a little more specific about what it is doing.
Old 12-27-2003, 11:23 PM
Should I get NiMH or NiCD or whatever? I don't get what the differences are. What is best for Xmods?
steering moter and 7/7 mod question grimmreap3r ZipZaps SE 0 07-16-2004 02:32 PM
