11-30-2003, 08:43 PM
what do u mean when you refer to the "leads" again?
11-30-2003, 09:48 PM
Paint X-fer?? UP YOURS!
Basically, change the polarity going through the LED.
Desolder the positive and negative leads going to the LED and switch them around.
StormVet
Freedom will be defended!
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
Suspension Upgrade (Hard rear - Soft Front)
Tire Upgrade (soft treaded)
AWD
Modded with alt-flashing red & blue LED's (Police lights in grill)
12-01-2003, 08:58 PM
ahhhh....ok thanks for clearing it up
12-02-2003, 05:23 PM
lights not flashing
okay, i did it the first time, but when i tried the setup again a second time, it didn't work. i didn't have time to go to Fry's so i picked up the following at my local RS:
1) 2xLED( one red one blue)
2)2x10uf/16v capacitor www
3)2x 33k ohm resistor
4)2x 330 hom resistor
5)2x 2N2222 transistor
after soldering everything toghether and using a 9v for the power source, the LEDs just stayed on......no flashing. can anyone tell me what i'm doin wrong here? funkytones, if you got it to work, could you hit me up on aim and tell me how u did it?thanks
12-02-2003, 06:45 PM
Re: lights not flashing
I hate to say it but I would suggest tracing everything back through each side of the circuit very carefully. You may not have one of the connections done properly.
The other thing that I'm not 100% certain about is the 2N2222 transistors. Most transistors should work but they could be the culprit.
You could test this theory by lowering the voltage being supplied to the circuit. Try dropping down to 6V or so.
Just a couple of suggestions for you. Not sure if they will solve your problem or not. Good luck!
StormVet
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
AWD
12-03-2003, 12:19 AM
nope... i got it almost all resoldered after i took it back apart... but one of the wires broke off one of the trans right next to the main part of it... so i have notheirg to solder it too... so i have stoped short of doing anything till i get another one...hehe... but still workin on it...hehe... tommorow i'll hit up RS...
12-04-2003, 10:14 PM
0reZepyT
looks sweet. did you setup three separate circuits or somehow combined it into one?
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
12-05-2003, 09:31 AM
That is AWESOME!!!!! Great Job!
Now, can you submit a post on how you did it? I'd love to see all of the details on that one.
Thanks!
StormVet
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
AWD
12-05-2003, 03:01 PM
Umm.. Teal Rsx
woop woop thats the sound of the police woop woop thats the sound of the beast
12-05-2003, 09:58 PM
oh wow u got it! and dam that's NIIIIIIIIIIIICE! well.......mine is still not workin properly. my blue led goes one, but my red one starts off ok then fades to off...... i've been looking over that schematic and what i did for at least a week now AND I STILL CAN"T GET IT! i got the right transistors (2n3904).....still didn't work. i was wondering......hey, funkytones, are you using the 10uf 16v tantalum capacitor or is it an electrolyte one like in the stormvet's pics?
12-06-2003, 12:16 AM
actually i scrapped making that circuit up above... i went to somthing totally different...hehe... look me up on aim and i'll might fill ya in
12-06-2003, 01:09 AM
0reZepyT
that's cool and all but i think we would all appreciate it if you posted it here for all of us to read. don't forget that this is a place to share information
12-08-2003, 10:03 PM
hm....hey stormvet, are you sure that the capacitors should be 10uf 16v, not 10uf 35v?
12-08-2003, 11:22 PM
Well, the one's that I used were 10uf 16v. And that is what the schematic called for.
StormVet
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
AWD
